ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-04-11T20:05:41+02:00 https://brainmodular.org/forums/app.php/feed/topic/3410 2012-04-11T20:05:41+02:00 2012-04-11T20:05:41+02:00 https://brainmodular.org/forums/viewtopic.php?t=3410&p=22972#p22972 <![CDATA[OSC: Usine to Usine]]> Statistics: Posted by r.erorr — 11 Apr 2012, 20:05
2012-04-11T19:47:23+02:00 2012-04-11T19:47:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=3410&p=22970#p22970 <![CDATA[OSC: Usine to Usine]]> but when you create your network in Ethernet i remember windows propose you several choices..?
any chance to test with an other PC in wifi mode..? or with an ipod or android phone ( with TouchOSC for example) ?
I've also see this recently, don"t have test yet but seems to be a cool solution for live show,
http://www.connectify.me/
will ask on the general forum if someone use this
Statistics: Posted by nay-seven — 11 Apr 2012, 19:47
2012-04-11T16:39:54+02:00 2012-04-11T16:39:54+02:00 https://brainmodular.org/forums/viewtopic.php?t=3410&p=22969#p22969 <![CDATA[OSC: Usine to Usine]]> but when you said "it's not the same to share files and to send/receive OSC" do you mean there is something I need to configure on my PC? I know only these steps IP adresse, subnet mask, workgroup, ping and firewall off - thats all.
Statistics: Posted by r.erorr — 11 Apr 2012, 16:39
2012-04-10T22:11:36+02:00 2012-04-10T22:11:36+02:00 https://brainmodular.org/forums/viewtopic.php?t=3410&p=22966#p22966 <![CDATA[OSC: Usine to Usine]]> OSC works fine in Usine, so must be in your wifi/ethernet configuration ?
Statistics: Posted by nay-seven — 10 Apr 2012, 22:11
2012-04-10T21:23:17+02:00 2012-04-10T21:23:17+02:00 https://brainmodular.org/forums/viewtopic.php?t=3410&p=22965#p22965 <![CDATA[OSC: Usine to Usine]]> Statistics: Posted by r.erorr — 10 Apr 2012, 21:23
2012-04-10T20:58:43+02:00 2012-04-10T20:58:43+02:00 https://brainmodular.org/forums/viewtopic.php?t=3410&p=22962#p22962 <![CDATA[OSC: Usine to Usine]]> about firewall better to disable it to test, then check Port number, etc
have you read this wiki page ?
Statistics: Posted by nay-seven — 10 Apr 2012, 20:58
2012-04-10T19:43:24+02:00 2012-04-10T19:43:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=3410&p=22960#p22960 <![CDATA[OSC: Usine to Usine]]> 1. global setup OSC is ON, and I can see outgoing messages
2. But I can't receive any messages on second PC
Statistics: Posted by r.erorr — 10 Apr 2012, 19:43
