ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-02-07T05:22:06+01:00 https://brainmodular.org/forums/app.php/feed/topic/3342 2012-02-07T05:22:06+01:00 2012-02-07T05:22:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=3342&p=22555#p22555 <![CDATA[Usine Saver]]>
Sorry, I missed your post somehow.
http://www.sensomusic.com/forums/upload ... 20box3.zip
Light Box
This is where I'm at with it right now. Just a couple of envelope followers and a LPF to try to pick up the drums. It's no where near ready for prime time and I've actually set it aside for the time being while I work on figuring out the best use of Usine with my live rig.
I looked at VVVV some time ago and decided I only need one enormous time suck in my life at a time.
Thanks for posting your music by the way.
-CCQ-
Statistics: Posted by CleverConQueso — 07 Feb 2012, 05:22
2012-02-04T20:48:53+01:00 2012-02-04T20:48:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=3342&p=22532#p22532 <![CDATA[Usine Saver]]> then you can link or not the hsl outs to hsl in of second module, leting free the inputs you wanna manually overide.
it's an interesting thing, im currently working on same direction for a festival live vj connected to sound via usine that decipher infos, trigger stuff too, we could share our findings. Ive chosen resolume wich, is not the best for 'generative' stuff but allow easy link with usine with OSC. it's possible ie to generate a square and change it's hue, move scale ect via osc.
Statistics: Posted by 23fx23 — 04 Feb 2012, 20:48
2012-02-04T20:39:50+01:00 2012-02-04T20:39:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=3342&p=22531#p22531 <![CDATA[Usine Saver]]> I suppose rather than using the color selector, I can start with the HSL and tweak it directly. That'll work.
- CCQ -
Statistics: Posted by CleverConQueso — 04 Feb 2012, 20:39
2012-02-04T20:33:00+01:00 2012-02-04T20:33:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=3342&p=22530#p22530 <![CDATA[Usine Saver]]> pass if change module will do the job..?
Statistics: Posted by nay-seven — 04 Feb 2012, 20:33
2012-02-04T19:58:29+01:00 2012-02-04T19:58:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=3342&p=22529#p22529 <![CDATA[Usine Saver]]>
Does anyone know if there's a way to unpack the output of the 'color selector' so that I can take the input in HSL and modify the S or L but keep the H?
-CCQ-
Statistics: Posted by CleverConQueso — 04 Feb 2012, 19:58
2012-02-03T07:46:45+01:00 2012-02-03T07:46:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=3342&p=22526#p22526 <![CDATA[Usine Saver]]> Statistics: Posted by nay-seven — 03 Feb 2012, 07:46
2012-02-03T03:09:03+01:00 2012-02-03T03:09:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=3342&p=22525#p22525 <![CDATA[Usine Saver]]>
I'm loosely basing it on this thing that a friend of mine has -
http://shopping.netsuite.com/s.nl/c.ACC ... egory=-102
This Thing
I've had pretty good results with how Usine layers the BMP outputs in the past.
I'm wondering if anyone else has taken on a similar effort or has seen VST applications that do this?
- CCQ -
Statistics: Posted by CleverConQueso — 03 Feb 2012, 03:09
Light Box
-CCQ-
- CCQ -
-CCQ-
This Thing
- CCQ -
