ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-01-10T18:09:05+02:00 https://brainmodular.org/forums/app.php/feed/topic/3313 2012-01-10T18:09:05+02:00 2012-01-10T18:09:05+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22308#p22308 <![CDATA[my new idea for a live set up using studio one pro and usine]]>
In that case add a Usine VST to each stem with the effects you want. Then create whatever GUI you want in a standalone Usine with your noturn attached to it and route midi from the stanalone Usine into S1 so you can control it all from the one GUI :)
awesome thanks
Statistics: Posted by ErotiCore SteNch — 10 Jan 2012, 17:09
2012-01-10T14:13:44+02:00 2012-01-10T14:13:44+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22307#p22307 <![CDATA[my new idea for a live set up using studio one pro and usine]]>
Statistics: Posted by caco — 10 Jan 2012, 13:13
2012-01-10T13:31:36+02:00 2012-01-10T13:31:36+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22306#p22306 <![CDATA[my new idea for a live set up using studio one pro and usine]]> Statistics: Posted by ErotiCore SteNch — 10 Jan 2012, 12:31
2012-01-10T10:26:23+02:00 2012-01-10T10:26:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22303#p22303 <![CDATA[my new idea for a live set up using studio one pro and usine]]>
Otherwise your alternatives are to use Jack or virtual audio cable to route audio between S1 and a standalone version of Usine but I think using VSTs would be easier to manage.
Statistics: Posted by caco — 10 Jan 2012, 09:26
2012-01-10T09:34:32+02:00 2012-01-10T09:34:32+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22301#p22301 <![CDATA[my new idea for a live set up using studio one pro and usine]]>
If S1 can be a Rewire slave, you could try the ReWire VST plugin from eXT. Another option could be a loopback of the audio (S1 output>driver/mixer software>loopback>Usine input) if the 1602 driver supports it.
If I understand you correctly, you want a fixed set of effects available per stem/track, so why not use Usine as insert VSTs? If you want to do some extra master MIDI stuff from Usine, you could also run an instance standalone at the same time with the "No audio" option, so you don't need an ASIO driver (and the extra CPU) for that.
Statistics: Posted by bsork — 10 Jan 2012, 08:34
2012-01-10T02:01:47+02:00 2012-01-10T02:01:47+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22300#p22300 <![CDATA[my new idea for a live set up using studio one pro and usine]]> so think i will have to wait untill (if)usine gets rewire,if theres not anyway other i can make this work:)
Statistics: Posted by ErotiCore SteNch — 10 Jan 2012, 01:01
2012-01-09T19:06:01+02:00 2012-01-09T19:06:01+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22297#p22297 <![CDATA[my new idea for a live set up using studio one pro and usine]]> Statistics: Posted by barabou — 09 Jan 2012, 18:06
2012-01-09T13:42:55+02:00 2012-01-09T13:42:55+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22296#p22296 <![CDATA[my new idea for a live set up using studio one pro and usine]]>
but no rewire support in Usine...so..? ;)
ahhh i thought there was rewire support in usine,because 23fx23 usine ableton thingie,i hope usine will see rewire support,would be a nice feature
Statistics: Posted by ErotiCore SteNch — 09 Jan 2012, 12:42
2012-01-09T08:46:56+02:00 2012-01-09T08:46:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22289#p22289 <![CDATA[my new idea for a live set up using studio one pro and usine]]>
Statistics: Posted by nay-seven — 09 Jan 2012, 07:46
2012-01-08T00:57:21+02:00 2012-01-08T00:57:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=3313&p=22285#p22285 <![CDATA[my new idea for a live set up using studio one pro and usine]]>
i produce all my tracks(DrumStep)in studio one pro
so my thought was to use studio one pro and have stems of my tracks
excample drums on track 1,bassline on track 2 etc
then use usine pro (maybe)rewired to studio one and have the corrosponding number of tracks in usineas the number of stems in S1
then have a button called play in usine that triggers the play button in S1
have different effects on the tracks in usine for the drum stem track,bass stem track etc
so i can choose what effect and where in the track i want to trigger the effects
all of this should be midi mapped to my novation nocturn
so my basic question is would rewire be the best way to connect S1 and usine for this?
Statistics: Posted by ErotiCore SteNch — 07 Jan 2012, 23:57
awesome thanks
