ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-01-13T21:49:36+02:00https://brainmodular.org/forums/app.php/feed/topic/33112012-01-13T21:49:36+02:002012-01-13T21:49:36+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22363#p22363Statistics: Posted by noise2sine — 13 Jan 2012, 20:49
2012-01-09T13:37:03+02:002012-01-09T13:37:03+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22295#p22295half screen for the patch ( add led and faders to visualize the actions of the patch) and on the other side with the dog ?
Statistics: Posted by nay-seven — 09 Jan 2012, 12:37
]]>2012-01-09T13:21:44+02:002012-01-09T13:21:44+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22294#p22294Statistics: Posted by noise2sine — 09 Jan 2012, 12:21
]]>2012-01-09T08:16:59+02:002012-01-09T08:16:59+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22288#p22288Statistics: Posted by nay-seven — 09 Jan 2012, 07:16
]]>2012-01-09T07:30:09+02:002012-01-09T07:30:09+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22287#p22287 Cheers
Statistics: Posted by noise2sine — 09 Jan 2012, 06:30
Statistics: Posted by noise2sine — 07 Jan 2012, 09:13
]]>2012-01-07T09:07:29+02:002012-01-07T09:07:29+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22280#p22280Statistics: Posted by CleverConQueso — 07 Jan 2012, 08:07
]]>2012-01-06T20:28:07+02:002012-01-06T20:28:07+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22279#p22279Statistics: Posted by tanabarbier — 06 Jan 2012, 19:28
]]>2012-01-06T19:51:19+02:002012-01-06T19:51:19+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22278#p22278 I will test this on the weekend and let you know
Thanks again
Statistics: Posted by noise2sine — 06 Jan 2012, 18:51
]]>2012-01-06T16:45:00+02:002012-01-06T16:45:00+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22277#p22277here a try ; threshold is used to set the sensibility of your micro then ( I've also a dog) generally the dogs don't do only a simple wouarf but more a wouarf woorf warf warf.. so i use a ramp , this way the first wouarf trigger the ramp and after a moment ( set by the length fader) the sampler play a random sample. ( record several different sentences will be better)
Statistics: Posted by nay-seven — 06 Jan 2012, 15:45
]]>2012-01-06T16:10:55+02:002012-01-06T16:10:55+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22276#p22276 To be honest i don't know where to start for doing a patch like this ! Can u help ?
Statistics: Posted by noise2sine — 06 Jan 2012, 15:10
]]>2012-01-06T15:00:00+02:002012-01-06T15:00:00+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22275#p22275 This must be the most original usage of Usine so far - poor dog!!!
]]>2012-01-06T14:21:32+02:002012-01-06T14:21:32+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22274#p22274 I wanted to create a patch in which an external sound captured with a mic, would trigger a sample in a sampler ? Basicly i need this patch to help my dog staying alone in my flat.So every time it would bark at a certain level, a sample with my voice would start , telling the dog to stay calm !
My neighbours would really appriciate if it's working !!
Statistics: Posted by noise2sine — 06 Jan 2012, 13:21
]]>BrainModularBrainModular Users Forum2012-01-13T21:49:36+02:00https://brainmodular.org/forums/app.php/feed/topic/33112012-01-13T21:49:36+02:002012-01-13T21:49:36+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22363#p22363Statistics: Posted by noise2sine — 13 Jan 2012, 20:49
]]>2012-01-09T13:37:03+02:002012-01-09T13:37:03+02:00https://brainmodular.org/forums/viewtopic.php?t=3311&p=22295#p22295half screen for the patch ( add led and faders to visualize the actions of the patch) and on the other side with the dog ?
Thanks again
