ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-12-29T23:40:14+02:00https://brainmodular.org/forums/app.php/feed/topic/32902011-12-29T23:40:14+02:002011-12-29T23:40:14+02:00https://brainmodular.org/forums/viewtopic.php?t=3290&p=22211#p22211Statistics: Posted by CleverConQueso — 29 Dec 2011, 22:40
2011-12-28T00:03:13+02:002011-12-28T00:03:13+02:00https://brainmodular.org/forums/viewtopic.php?t=3290&p=22197#p22197 You can use the driver asio4all (freeware), it allows you to use your internal sound card with all the asio hosts ...
]]>2011-12-27T17:08:56+02:002011-12-27T17:08:56+02:00https://brainmodular.org/forums/viewtopic.php?t=3290&p=22194#p22194Statistics: Posted by senso — 27 Dec 2011, 16:08
]]>2011-12-20T18:33:05+02:002011-12-20T18:33:05+02:00https://brainmodular.org/forums/viewtopic.php?t=3290&p=22155#p22155in Win 7 i must put the audio on "spdif "to have sound in usine it's the only which do that i don't know why if somebody can explain me why .......? i have magix which works with both "speakers" and spdif audacity also so why usine only functiuns with " spdif " thanx
Statistics: Posted by waolelaid — 20 Dec 2011, 17:33
]]>2011-12-19T21:00:13+02:002011-12-19T21:00:13+02:00https://brainmodular.org/forums/viewtopic.php?t=3290&p=22146#p22146Any thoughts on enabling integration with Windows Audio for use with Usine? Two reasons - 1- Windows Audio support would lower the bar for a new user to join the Usine family while they are learning about the advantages of lower latency audio. 2- The very cool 'save as exe' feature would be more useful in that you would be able to share audio applications with folks who have not adopted ASIO. Thanks - CCQ -
Statistics: Posted by CleverConQueso — 19 Dec 2011, 20:00
]]>BrainModularBrainModular Users Forum2011-12-29T23:40:14+02:00https://brainmodular.org/forums/app.php/feed/topic/32902011-12-29T23:40:14+02:002011-12-29T23:40:14+02:00https://brainmodular.org/forums/viewtopic.php?t=3290&p=22211#p22211Statistics: Posted by CleverConQueso — 29 Dec 2011, 22:40
]]>2011-12-28T00:03:13+02:002011-12-28T00:03:13+02:00https://brainmodular.org/forums/viewtopic.php?t=3290&p=22197#p22197 You can use the driver asio4all (freeware), it allows you to use your internal sound card with all the asio hosts ...
