ArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-08-09T10:56:21+02:00https://brainmodular.org/forums/app.php/feed/topic/32872012-08-09T10:56:21+02:002012-08-09T10:56:21+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=24024#p24024is that the folder where the Usine VST is- contains also the .dll for the VST used in the patch. This is the method that MAX/msp use. Cheers 8D
Statistics: Posted by artificial — 08 Aug 2012, 19:22
]]>2012-08-06T18:56:14+02:002012-08-06T18:56:14+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=24009#p24009 Yes, you missed a small detail.
The window size is exactly the VST size when you export your plug-in. You just have to decide the size before exporting it to have exactly the same on finish.
Best
Statistics: Posted by multiphone — 06 Aug 2012, 18:56
]]>2012-08-06T18:30:23+02:002012-08-06T18:30:23+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=24008#p24008Statistics: Posted by artificial — 06 Aug 2012, 18:30
2012-08-05T19:42:06+02:002012-08-05T19:42:06+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=23995#p23995of SynthMaker and Usine modules, if I want to share products. For example- I want to use the Usine local synchro to clock a MIDI sequencer that has been built with SM. For my users, it is not possible to specify the file path of my SM component. Thanks Senso. I think a reasonably simple solution is to have a VST folder option for the exported Usine VSTi. edit- This problem also occurs in exported .exe s. hmm, if there was a solution I would be very happy, because Usine has solved timing issues in 2 projects on my system. I could then distribute them as products.
]]>2011-12-27T16:55:43+02:002011-12-27T16:55:43+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=22192#p22192Let me think about this but the exported vst is designed to have the simplest setup as possible, so?
Oh, and being able to export a VST with multi i/o would be a big plus! Autodect how many inputs/ outputs are active in the workspace and apply it to the VST when exporting.
Export with Easine does!
Also if each exported VST could share a common data folder would be nice as it gets cluttered and uses a lot of drive space with each VST creating it's own.
It's not the background idea of the exportation: be independent.
]]>2011-12-20T00:59:21+02:002011-12-20T00:59:21+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=22150#p22150 Also if each exported VST could share a common data folder would be nice as it gets cluttered and uses a lot of drive space with each VST creating it's own.
Statistics: Posted by gurulogic — 19 Dec 2011, 23:59
]]>2011-12-19T11:23:56+02:002011-12-19T11:23:56+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=22134#p22134was exported so any system changes could be catastophic to any saved work and also the loadpatch module is unable to work from the exported VST so I am unable to use the Usine VST as a VST loader. It would be nice if the exported VST could still have the VST and Usine Library folder paths setup option available spo that the exported VST could be a usable VST host and also be able to load predetermined patches.
Statistics: Posted by gurulogic — 19 Dec 2011, 10:23
]]>BrainModularBrainModular Users Forum2012-08-09T10:56:21+02:00https://brainmodular.org/forums/app.php/feed/topic/32872012-08-09T10:56:21+02:002012-08-09T10:56:21+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=24024#p24024is that the folder where the Usine VST is- contains also the .dll for the VST used in the patch. This is the method that MAX/msp use. Cheers 8D
Best
]]>2012-08-05T19:42:06+02:002012-08-05T19:42:06+02:00https://brainmodular.org/forums/viewtopic.php?t=3287&p=23995#p23995of SynthMaker and Usine modules, if I want to share products. For example- I want to use the Usine local synchro to clock a MIDI sequencer that has been built with SM. For my users, it is not possible to specify the file path of my SM component. Thanks Senso. I think a reasonably simple solution is to have a VST folder option for the exported Usine VSTi. edit- This problem also occurs in exported .exe s. hmm, if there was a solution I would be very happy, because Usine has solved timing issues in 2 projects on my system. I could then distribute them as products.
