Statistics: Posted by musikmachine — 20 Dec 2011, 23:06
]]>2011-12-20T22:29:40+02:002011-12-20T22:29:40+02:00https://brainmodular.org/forums/viewtopic.php?t=3286&p=22157#p22157Usine or any soft can't generate a BSOD itself. It's one of your driver or the physical memory.
]]>2011-12-20T00:51:17+02:002011-12-20T00:51:17+02:00https://brainmodular.org/forums/viewtopic.php?t=3286&p=22149#p22149Statistics: Posted by gurulogic — 19 Dec 2011, 23:51
]]>2011-12-19T22:53:23+02:002011-12-19T22:53:23+02:00https://brainmodular.org/forums/viewtopic.php?t=3286&p=22148#p22148 and hope you'll find the good settings for your soundcard
Statistics: Posted by nay-seven — 19 Dec 2011, 21:53
That with a touchscreen would be stunning! That's what's been going through my mind when i've been playing with the demo, building on existing plugins and modifying them to create hybrid mutations. Will you be releasing that?
Anyway, i think it's an issue with my Quartet. I changed the buffer size via the Quartets main control panel this triggered a really loud nasty buzzing sound, switched buffer size and sample rate which resulted in another bsod. After rebooting and bsoding a couple of times the desktop ended up in a post reboot loop so i shut it down and left it till today. I've removed the driver for now and eventually i got the Konnkekt 6 driver to work but it took a bit of playing around with the settings in Usine.
Statistics: Posted by musikmachine — 19 Dec 2011, 21:23
]]>2011-12-19T19:57:53+02:002011-12-19T19:57:53+02:00https://brainmodular.org/forums/viewtopic.php?t=3286&p=22142#p22142check this interface made in Usine for Aalto: http://vimeo.com/32030268
Statistics: Posted by nay-seven — 19 Dec 2011, 18:57
Starting and stopping the driver doesn't do anything with the native asio drivers but switching to asio4all it works, still no audio though. Had a similar issue with my laptop at first but it's been fine since.
Interfaces are a TC Konnekt 6 and an Infrasonic Quartet on my desktop and NI AK1 on my laptop. I guess i need to overwrite the installation but i'll reboot first and see if that fixes it.
Cheers.
Oh yeah, i'm using the pro demo.
Statistics: Posted by musikmachine — 19 Dec 2011, 03:02
]]>BrainModularBrainModular Users Forum2011-12-21T02:53:33+02:00https://brainmodular.org/forums/app.php/feed/topic/32862011-12-21T02:53:33+02:002011-12-21T02:53:33+02:00https://brainmodular.org/forums/viewtopic.php?t=3286&p=22162#p22162Statistics: Posted by musikmachine — 21 Dec 2011, 01:53
]]>2011-12-21T00:06:25+02:002011-12-21T00:06:25+02:00https://brainmodular.org/forums/viewtopic.php?t=3286&p=22160#p22160
Cheers.
