I don't usually use the bypass path inside the VST so i use a mute to kill the signal after the vst. What happens here is that when you press on the bypass switch to turn on the effect, the effects is unbypassed, and then after a slight delay the mute comes off, to avoid the clicking sound of the vst activation. When you press the bypass switch again to turn off the effect, the mute takes place first and then the effect is bypassed to avoid the clicking again. I'm open to better suggestions...
The smooth feature inside the volume/mute module is cool in itself, but what would be needed for our purpose here is a FAST MUTE + SLOW UNMUTE MODE. This would allow me to ditch my sub patches and gain some cpu power...
]]>2011-12-04T21:51:23+02:002011-12-04T21:51:23+02:00https://brainmodular.org/forums/viewtopic.php?t=3260&p=21985#p21985I mean a small fade in/out when the "bypass" is activated.
]]>2011-12-03T04:11:01+02:002011-12-03T04:11:01+02:00https://brainmodular.org/forums/viewtopic.php?t=3260&p=21970#p21970Statistics: Posted by gurulogic — 03 Dec 2011, 03:11
]]>BrainModularBrainModular Users Forum2012-03-22T05:51:22+02:00https://brainmodular.org/forums/app.php/feed/topic/32602012-03-22T05:51:22+02:002012-03-22T05:51:22+02:00https://brainmodular.org/forums/viewtopic.php?t=3260&p=22817#p22817Statistics: Posted by 23fx23 — 22 Mar 2012, 04:51
]]>2012-03-22T04:34:31+02:002012-03-22T04:34:31+02:00https://brainmodular.org/forums/viewtopic.php?t=3260&p=22814#p22814
