ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-11-29T10:49:06+01:00 https://brainmodular.org/forums/app.php/feed/topic/3256 2011-11-29T10:49:06+01:00 2011-11-29T10:49:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=3256&p=21952#p21952 <![CDATA[getset VST params]]> Statistics: Posted by gurulogic — 29 Nov 2011, 10:49
2011-11-29T09:22:51+01:00 2011-11-29T09:22:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=3256&p=21951#p21951 <![CDATA[getset VST params]]> Image
Statistics: Posted by nay-seven — 29 Nov 2011, 09:22
2011-11-29T09:13:45+01:00 2011-11-29T09:13:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=3256&p=21950#p21950 <![CDATA[getset VST params]]> Statistics: Posted by gurulogic — 29 Nov 2011, 09:13
2011-11-29T08:25:49+01:00 2011-11-29T08:25:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=3256&p=21949#p21949 <![CDATA[getset VST params]]>
Statistics: Posted by nay-seven — 29 Nov 2011, 08:25
2011-11-29T00:32:57+01:00 2011-11-29T00:32:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=3256&p=21948#p21948 <![CDATA[getset VST params]]> Statistics: Posted by gurulogic — 29 Nov 2011, 00:32
2011-11-28T12:49:03+01:00 2011-11-28T12:49:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=3256&p=21945#p21945 <![CDATA[getset VST params]]> interesting patch, not easy at first and maybe a poly version can be more easy and clean when adding more faders..?
an other little thing i see: you set switch to group 1, but don't work in sub-patchs
Statistics: Posted by nay-seven — 28 Nov 2011, 12:49
2011-11-28T09:08:05+01:00 2011-11-28T09:08:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=3256&p=21942#p21942 <![CDATA[getset VST params]]>
(in some cases Usine will learn the parameter just fine from the plugin UI, but in other cases you need to go to the plugin parameter list
to learn the control to Usine. I believe this is because these plugins only send their parameter values for a fraction of a second when the UI control is released, and then immediately reset their index values which makes it impossible to learn them to Usine via the UI. If anyone has any ideas how to work around this? It would be great if all plugins could be learned via the UI!)
Statistics: Posted by gurulogic — 28 Nov 2011, 09:08
