ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-05-16T07:37:22+01:00 https://brainmodular.org/forums/app.php/feed/topic/3246 2012-05-16T07:37:22+01:00 2012-05-16T07:37:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23318#p23318 <![CDATA[New ! Synthesis Pack v 2.0]]> btw, I've updated the pack, this DLL was in the the 1.3 update so i suppose many of us have it in a dir somewhere and i realize Usine (or windows) find it even if it was not with the patch .
sorry for that.
Statistics: Posted by nay-seven — 16 May 2012, 08:37
2012-05-16T03:38:37+01:00 2012-05-16T03:38:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23313#p23313 <![CDATA[New ! Synthesis Pack v 2.0]]> So it is the right one, I only had to re cable betwen the array and the vst, but that's it! Thanks for this patch Nay!
Statistics: Posted by tanabarbier — 16 May 2012, 04:38
2012-05-15T20:51:38+01:00 2012-05-15T20:51:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23312#p23312 <![CDATA[New ! Synthesis Pack v 2.0]]> download
Statistics: Posted by nay-seven — 15 May 2012, 21:51
2012-05-15T17:36:57+01:00 2012-05-15T17:36:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23311#p23311 <![CDATA[New ! Synthesis Pack v 2.0]]> I don't get it...
Statistics: Posted by tanabarbier — 15 May 2012, 18:36
2012-05-15T07:39:58+01:00 2012-05-15T07:39:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23306#p23306 <![CDATA[New ! Synthesis Pack v 2.0]]> Once again, you don't need to put them in the user dir or in your vst, just keep the dll dir with the patch, but be sure to delete old ones.
Try this : use a fresh install of Usine, unpack all the synthesis pack and choose this dir as library path in your setup ( don't change anything more) and check if it' work for you .
Statistics: Posted by nay-seven — 15 May 2012, 08:39
2012-05-14T23:20:48+01:00 2012-05-14T23:20:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23304#p23304 <![CDATA[New ! Synthesis Pack v 2.0]]> Something that seems weird to me: The synthpack 2.0 is from 2011, no? Because when I open the .rar and look inside the DLL folder the files dates are all about 2008...
Statistics: Posted by tanabarbier — 15 May 2012, 00:20
2012-05-14T23:14:58+01:00 2012-05-14T23:14:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23302#p23302 <![CDATA[New ! Synthesis Pack v 2.0]]> you can also let the DLL dir in the same than the patchs in your library
Statistics: Posted by nay-seven — 15 May 2012, 00:14
2012-05-14T22:27:36+01:00 2012-05-14T22:27:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23301#p23301 <![CDATA[New ! Synthesis Pack v 2.0]]> I downloaded it at least 4 times (from the add on section), even tried to open directly the dll only and it is the old one.
Is there something I am doing wrong?
Statistics: Posted by tanabarbier — 14 May 2012, 23:27
2012-05-13T18:28:45+01:00 2012-05-13T18:28:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23277#p23277 <![CDATA[New ! Synthesis Pack v 2.0]]>
Statistics: Posted by Floego — 13 May 2012, 19:28
2012-05-12T09:35:49+01:00 2012-05-12T09:35:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23265#p23265 <![CDATA[New ! Synthesis Pack v 2.0]]> Maybe you can create a new topic and propose a collaborative challenge " create a collaborative synthesis drum set for Usine"
Statistics: Posted by nay-seven — 12 May 2012, 10:35
2012-05-12T02:07:13+01:00 2012-05-12T02:07:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=23264#p23264 <![CDATA[New ! Synthesis Pack v 2.0]]> I wonder if anyone has tried to create percussive patches with this synths? I mean, electronic snare, kickdrum, hihat, bongos, etc.
could be great to have an usine-only synth drum! :D
Statistics: Posted by Floego — 12 May 2012, 03:07
2012-02-06T16:21:00+01:00 2012-02-06T16:21:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=22542#p22542 <![CDATA[New ! Synthesis Pack v 2.0]]> Statistics: Posted by durkkooistra — 06 Feb 2012, 16:21
2011-12-08T13:44:48+01:00 2011-12-08T13:44:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=22026#p22026 <![CDATA[New ! Synthesis Pack v 2.0]]> Statistics: Posted by grego mondo — 08 Dec 2011, 13:44
2011-12-06T08:54:48+01:00 2011-12-06T08:54:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=22005#p22005 <![CDATA[New ! Synthesis Pack v 2.0]]> Statistics: Posted by nay-seven — 06 Dec 2011, 08:54
2011-12-05T23:50:15+01:00 2011-12-05T23:50:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=22002#p22002 <![CDATA[New ! Synthesis Pack v 2.0]]>
I'll try downloading again.
Thanks.Image
Statistics: Posted by CleverConQueso — 05 Dec 2011, 23:50
2011-12-05T20:41:00+01:00 2011-12-05T20:41:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=22001#p22001 <![CDATA[New ! Synthesis Pack v 2.0]]> Image
Statistics: Posted by nay-seven — 05 Dec 2011, 20:41
2011-12-05T19:48:13+01:00 2011-12-05T19:48:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=22000#p22000 <![CDATA[New ! Synthesis Pack v 2.0]]> Do you mind checking the patch for 'additive'? I think there's something amiss with how the array is routed?
-CCQ-
Statistics: Posted by CleverConQueso — 05 Dec 2011, 19:48
2011-11-18T20:24:48+01:00 2011-11-18T20:24:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=21885#p21885 <![CDATA[New ! Synthesis Pack v 2.0]]> a good night in prospect :D
Statistics: Posted by waolelaid — 18 Nov 2011, 20:24
2011-11-18T20:19:32+01:00 2011-11-18T20:19:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=21884#p21884 <![CDATA[New ! Synthesis Pack v 2.0]]> -CCQ-
Statistics: Posted by CleverConQueso — 18 Nov 2011, 20:19
2011-11-18T19:19:37+01:00 2011-11-18T19:19:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=21883#p21883 <![CDATA[New ! Synthesis Pack v 2.0]]>
Statistics: Posted by Floego — 18 Nov 2011, 19:19
2011-11-18T17:08:28+01:00 2011-11-18T17:08:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=3246&p=21882#p21882 <![CDATA[New ! Synthesis Pack v 2.0]]>
New version !
Synthesis pack v2.0 is a pack of patches with plugins inside made with synthmaker and Synthedit .
Some new layouts and some littles modifications for this new version.
on/off button for each patches
midi/drone option for some of them
You’ll find 2 types of patches : Oscillators ( OSC ), some basic vsti synthesizers ( SYN ) and an overview workspace to open all of them at once
more infos
Statistics: Posted by nay-seven — 18 Nov 2011, 17:08
sorry for that.
Thanks.Image
-CCQ-
New version !
more infos
