ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-11-09T01:49:47+02:00 https://brainmodular.org/forums/app.php/feed/topic/3229 2011-11-09T01:49:47+02:00 2011-11-09T01:49:47+02:00 https://brainmodular.org/forums/viewtopic.php?t=3229&p=21795#p21795 <![CDATA[Fades in and out when looping]]> http://www.sensomusic.com/forums/upload ... antize.pat
Statistics: Posted by tanabarbier — 09 Nov 2011, 00:49
2011-11-09T01:22:49+02:00 2011-11-09T01:22:49+02:00 https://brainmodular.org/forums/viewtopic.php?t=3229&p=21794#p21794 <![CDATA[Fades in and out when looping]]> It seems to be working, could anyone check this ? I'm really not shure...
http://www.sensomusic.com/forums/upload ... 0fades.pat
Thanks a lot !
Statistics: Posted by tanabarbier — 09 Nov 2011, 00:22
2011-11-07T23:16:51+02:00 2011-11-07T23:16:51+02:00 https://brainmodular.org/forums/viewtopic.php?t=3229&p=21787#p21787 <![CDATA[Fades in and out when looping]]>
Last time, I used ASR modules and in fact I retain it for my new patch, I suggest you to try that, because ASR does a lot of the ramp job and parametrize
http://www.sensomusic.com/forums/uploads.php?file=2011-11-07%2022-14-22.png
Statistics: Posted by GDLive — 07 Nov 2011, 22:16
2011-11-07T10:50:59+02:00 2011-11-07T10:50:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=3229&p=21778#p21778 <![CDATA[Fades in and out when looping]]> there 's also some addons from GDlive and joffo around this i think
Statistics: Posted by nay-seven — 07 Nov 2011, 09:50
2011-11-07T06:07:26+02:00 2011-11-07T06:07:26+02:00 https://brainmodular.org/forums/viewtopic.php?t=3229&p=21776#p21776 <![CDATA[Fades in and out when looping]]> I might havent understood how work your patch, or I explained badly what I need, but I can't make it do what I want.
I tried a bit tonight, and here is the patch :
http://www.megaupload.com/?d=XGWRT4SK
I'm not shure it works well, and my problem is with quantized loops, the way I'm doing it the loops will have a duration of, for exemple, one bar plus the fade out time, and so it won't be that much "quantized"...
When something is being quantized there is a fader on the up left corner of usine, is there a way to colect the data coming out of this fader ?
Statistics: Posted by tanabarbier — 07 Nov 2011, 05:07
2011-11-07T01:30:05+02:00 2011-11-07T01:30:05+02:00 https://brainmodular.org/forums/viewtopic.php?t=3229&p=21775#p21775 <![CDATA[Fades in and out when looping]]>
I use mono samplers but it's easy to adapt for stereo or multi-channel.
http://www.sensomusic.com/forums/upload ... ssfade.wkp
Statistics: Posted by r.erorr — 07 Nov 2011, 00:30
2011-11-07T00:54:25+02:00 2011-11-07T00:54:25+02:00 https://brainmodular.org/forums/viewtopic.php?t=3229&p=21774#p21774 <![CDATA[Fades in and out when looping]]> I'd like to find a way to put short fades in and out at the beginning and ending of the recording of a loop, to avoid clics. I was thinking to use a ramp, starting when rec is pushed, and an other when rec is released, and a data delay to wait until the ramp ends to stop recording, any advice ?
My biggest problem is with the quantized loops, for the fade out, how could I make the ramp start a few ms (it's own duration) before the end of cycle (or any other quantize value) ?
Any suggestion is super welcome !
Thanks !
Statistics: Posted by tanabarbier — 06 Nov 2011, 23:54
Thanks a lot !
Thanks !
