ArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-10-21T16:51:42+02:00https://brainmodular.org/forums/app.php/feed/topic/31962011-10-21T16:51:42+02:002011-10-21T16:51:42+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21676#p21676 but please report issues by mail!
Statistics: Posted by nay-seven — 21 Oct 2011, 16:51
]]>2011-10-21T16:09:21+02:002011-10-21T16:09:21+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21675#p21675not when I use usine my computer seems to work fine, it work fine also in usine when I connect my modules correctly.
cpu protect is set to 95%, nb threads 8, usine pro 5.50.521 windows 7 64, core2duo 6gb of ram
Statistics: Posted by jeanrene — 21 Oct 2011, 16:09
]]>2011-10-11T09:11:29+02:002011-10-11T09:11:29+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21603#p21603Statistics: Posted by senso — 11 Oct 2011, 09:11
2011-10-11T06:25:32+02:002011-10-11T06:25:32+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21601#p21601I can save my main workspace only if I take the master track off, and then no pb, but otherwise imposible. And then I can put it back when opening and it works fine. A bit strange.
Statistics: Posted by tanabarbier — 11 Oct 2011, 06:25
]]>2011-10-11T06:05:01+02:002011-10-11T06:05:01+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21600#p21600 I always saveAs and restart whenever I see one, otherwise I get burned. I also independently saveAs any patches I've been working on.....
Statistics: Posted by woodslanding — 11 Oct 2011, 06:05
]]>2011-10-11T05:22:16+02:002011-10-11T05:22:16+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21598#p21598Statistics: Posted by Floego — 11 Oct 2011, 05:22
]]>2011-10-11T04:53:23+02:002011-10-11T04:53:23+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21597#p21597 I have not been able to pin it down either....
Statistics: Posted by woodslanding — 11 Oct 2011, 04:53
]]>2011-10-10T19:24:48+02:002011-10-10T19:24:48+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21594#p21594not realy a patching question, but I get this "Error: Internal" message a lot when trying to save a patch, a track, a workspace, and when it happens then I can't save anything more. For all the testing I've done it seems to be due to something that have to do with audio buses in my case, but how could I fix or do anything regarding that ? I know it is very vague, but I really don't get anything !
Anybody getting the same problem ?
thanks in advance !
Statistics: Posted by tanabarbier — 10 Oct 2011, 19:24
]]>BrainModularBrainModular Users Forum2011-10-21T16:51:42+02:00https://brainmodular.org/forums/app.php/feed/topic/31962011-10-21T16:51:42+02:002011-10-21T16:51:42+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21676#p21676 but please report issues by mail!
]]>2011-10-11T06:25:32+02:002011-10-11T06:25:32+02:00https://brainmodular.org/forums/viewtopic.php?t=3196&p=21601#p21601I can save my main workspace only if I take the master track off, and then no pb, but otherwise imposible. And then I can put it back when opening and it works fine. A bit strange.
thanks in advance !
