ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-10-09T20:44:47+01:00 https://brainmodular.org/forums/app.php/feed/topic/3194 2011-10-09T20:44:47+01:00 2011-10-09T20:44:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21593#p21593 <![CDATA[Step CCQNCR Add-On Uploaded]]>
Statistics: Posted by nay-seven — 09 Oct 2011, 21:44
2011-10-09T20:37:27+01:00 2011-10-09T20:37:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21592#p21592 <![CDATA[Step CCQNCR Add-On Uploaded]]> Statistics: Posted by CleverConQueso — 09 Oct 2011, 21:37
2011-10-09T20:02:50+01:00 2011-10-09T20:02:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21591#p21591 <![CDATA[Step CCQNCR Add-On Uploaded]]> about RAM/cpu use , not sure but the more precision you ask , of course need more calculations
Statistics: Posted by nay-seven — 09 Oct 2011, 21:02
2011-10-09T19:42:29+01:00 2011-10-09T19:42:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21590#p21590 <![CDATA[Step CCQNCR Add-On Uploaded]]>
And on the line resolution - I wanted to use it for long transitions like cutoff filter curves and since the user can specify many bars length, I figured the highest resolution would reduce notchiness. (Quantization) Plus its hard to exactly predict when a bar will begin and end on that UI, particularly at scale so I figured it's good for trends. Do I pay for the 1024 in RAM or is there a better UI I should look at? XY with memory?
Statistics: Posted by CleverConQueso — 09 Oct 2011, 20:42
2011-10-09T09:49:44+01:00 2011-10-09T09:49:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21587#p21587 <![CDATA[Step CCQNCR Add-On Uploaded]]> I've just add a display number module from the slide to view fader in the pop up window.
This way even if you let the pop up open for a while, you always know on which pattern you work.
a last detail i don't understand is the resolution you choose for the lines of LTR1 ..1024 is not easy to edit, but maybe there's a specific reason..?
Statistics: Posted by nay-seven — 09 Oct 2011, 10:49
2011-10-09T06:26:33+01:00 2011-10-09T06:26:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21585#p21585 <![CDATA[Step CCQNCR Add-On Uploaded]]> Still haven't mastered the art of linking to the forum and WIKI yet... (Sorry Senso)
Please let me know your thoughts.
- CCQ -
Statistics: Posted by CleverConQueso — 09 Oct 2011, 07:26
2011-10-08T08:42:27+01:00 2011-10-08T08:42:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21583#p21583 <![CDATA[Step CCQNCR Add-On Uploaded]]>
in the main window, there ( for my part) too much confusion too, edit/load/display...? maybe a way to simplify this..?
i imagine the big 8 button we have when we save could be in the main window , i click on 2 i see 2, can edit , then click on save if i need
you see what i mean..?
once again, it's you're baby and it's only my thoughts.:)
about the add-ons page , when you click on modify you can change only the picture or only the text ( I've add direct link btw ) or only the addon file ( but you have to use a different name )
Statistics: Posted by nay-seven — 08 Oct 2011, 09:42
2011-10-08T00:14:45+01:00 2011-10-08T00:14:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21582#p21582 <![CDATA[Step CCQNCR Add-On Uploaded]]> Please take a look and let me know your thoughts.
On the add-on's screen, there's a link to delete an existing add-on or modify it. My question above was about how modify works. I think maybe it doesn't which is not the end of the world since delete does so you can delete and re-upload.
-CCQ-
Statistics: Posted by CleverConQueso — 08 Oct 2011, 01:14
2011-10-06T18:44:10+01:00 2011-10-06T18:44:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21581#p21581 <![CDATA[Step CCQNCR Add-On Uploaded]]> i suppose could be cool to have a big 2 when we are on sequence 2, and if i decide to save it , on click on save must be enough..and so, do you see what i mean..? in a word : process simplification :)
about wiki wasn't me, maybe senso.
best way to create wiki page is to start from the patch , click on the ? in the patch
Statistics: Posted by nay-seven — 06 Oct 2011, 19:44
2011-10-06T18:00:46+01:00 2011-10-06T18:00:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21580#p21580 <![CDATA[Step CCQNCR Add-On Uploaded]]>
I'm with you on the 'why doesn't it play when I start clicking notes' question. I don't know what the right workflow is for that other than a live mode, maybe. I'll play with it. I also have to fix the colors and a default setting in the scheduler, both of which I managed to mess up right before uploading.
When you say - "No way to stop/play the sequences directly" do you mean, no way to stop the notes by pressing a button that pauses the matrix loop? How about a button that sends a midi off and bypasses the midi outputs of the sequencer? 'Mute' or 'silience'? Stopping the loop might be confusing since it will start up bar/cycle matched, so there will be a jump.
About re-uploading - When I click on 'change this add-on' on the add-ons screen, it scrolls down to the uploader but none of the information is pre-filled. Is the workflow to upload a new one with new comments and just delete the old one? I'd also like to fix the link to the Wiki page.
Edit - Hey! You fixed the WIKI link and the image too, I see. What was the trick to make the image come out right? I was using a PNG file, is that the wrong approach? /Edit
Thanks for looking at it. I've been using the sequencer a lot lately and I want it to be useful for others as well but I am worried that it will look like the inside of my brain rather than something that everyone can use.
- CCQ -
Statistics: Posted by CleverConQueso — 06 Oct 2011, 19:00
2011-10-06T11:26:08+01:00 2011-10-06T11:26:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21574#p21574 <![CDATA[Step CCQNCR Add-On Uploaded]]> )
seriously, 2 little thought, maybe a little annoying thing for new users is that you don't have any sound first ( even with a vsti linked ) when you add your first notes, you need to save first..?
and no way to stop/play directly the sequences?
Statistics: Posted by nay-seven — 06 Oct 2011, 12:26
2011-10-05T22:14:32+01:00 2011-10-05T22:14:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=3194&p=21570#p21570 <![CDATA[Step CCQNCR Add-On Uploaded]]>
- CCQ -
WIKI Page
Statistics: Posted by CleverConQueso — 05 Oct 2011, 23:14
- CCQ -
-CCQ-
- CCQ -
- CCQ -
WIKI Page
