Statistics: Posted by woodslanding — 04 Oct 2011, 17:49
]]>2011-10-04T16:48:24+01:002011-10-04T16:48:24+01:00https://brainmodular.org/forums/viewtopic.php?t=3190&p=21546#p21546Statistics: Posted by woodslanding — 04 Oct 2011, 17:48
2011-10-04T08:02:10+01:002011-10-04T08:02:10+01:00https://brainmodular.org/forums/viewtopic.php?t=3190&p=21542#p21542Statistics: Posted by nay-seven — 04 Oct 2011, 09:02
]]>2011-10-04T07:15:23+01:002011-10-04T07:15:23+01:00https://brainmodular.org/forums/viewtopic.php?t=3190&p=21538#p21538 To do this, I take the out from the fader, run it into an OnlyIfChanged module, and use the output of this to control a PassEvent module, with a 1 on its input. As expected, every time I change the slider, the PE module sends out this: 1 [-1]
But for whatever reason, this does not change the value of the parameter. If it is off, it stays off. I put a switch on the parameter just to be sure, and that works fine.
Any ideas what to do???
Thanks! -eric
Statistics: Posted by woodslanding — 04 Oct 2011, 08:15
]]>2011-10-04T08:02:10+01:002011-10-04T08:02:10+01:00https://brainmodular.org/forums/viewtopic.php?t=3190&p=21542#p21542Statistics: Posted by nay-seven — 04 Oct 2011, 09:02
Thanks! -eric
