ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-01-29T12:46:12+01:00 https://brainmodular.org/forums/app.php/feed/topic/3185 2012-01-29T12:46:12+01:00 2012-01-29T12:46:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=22469#p22469 <![CDATA[New add-on /VST Homing Pad]]>
btw, can i suggest you to maybe add this as a add_on and add it in the Add-ons discussion topic for a better visibility..?
Statistics: Posted by nay-seven — 29 Jan 2012, 12:46
2012-01-29T11:49:39+01:00 2012-01-29T11:49:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=22468#p22468 <![CDATA[New add-on /VST Homing Pad]]> Here I made something very very simple, but the same trajectory concept works like homing pad
http://www.sensomusic.com/forums/upload ... ampler.pat
Statistics: Posted by r.erorr — 29 Jan 2012, 11:49
2011-10-19T19:48:20+01:00 2011-10-19T19:48:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21669#p21669 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by héliouk 6 — 19 Oct 2011, 20:48
2011-10-13T08:02:20+01:00 2011-10-13T08:02:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21619#p21619 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by nay-seven — 13 Oct 2011, 09:02
2011-10-12T19:18:02+01:00 2011-10-12T19:18:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21616#p21616 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by pro65 — 12 Oct 2011, 20:18
2011-10-05T04:10:28+01:00 2011-10-05T04:10:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21560#p21560 <![CDATA[New add-on /VST Homing Pad]]>
- CCQ -
Statistics: Posted by CleverConQueso — 05 Oct 2011, 05:10
2011-10-04T23:02:58+01:00 2011-10-04T23:02:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21554#p21554 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by tanabarbier — 05 Oct 2011, 00:02
2011-10-04T20:34:49+01:00 2011-10-04T20:34:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21552#p21552 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by Floego — 04 Oct 2011, 21:34
2011-10-04T20:02:10+01:00 2011-10-04T20:02:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21550#p21550 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by r.erorr — 04 Oct 2011, 21:02
2011-10-03T23:47:46+01:00 2011-10-03T23:47:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21535#p21535 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by 23fx23 — 04 Oct 2011, 00:47
2011-10-03T23:42:28+01:00 2011-10-03T23:42:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21533#p21533 <![CDATA[New add-on /VST Homing Pad]]> Statistics: Posted by Clearscreen — 04 Oct 2011, 00:42
2011-10-03T15:20:48+01:00 2011-10-03T15:20:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21526#p21526 <![CDATA[New add-on /VST Homing Pad]]>
Statistics: Posted by nay-seven — 03 Oct 2011, 16:20
2011-10-03T14:31:43+01:00 2011-10-03T14:31:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21522#p21522 <![CDATA[New add-on /VST Homing Pad]]> it seems to be very simple and very fun to make music with your addon. !
Statistics: Posted by joffo78 — 03 Oct 2011, 15:31
2011-10-03T14:09:47+01:00 2011-10-03T14:09:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=3185&p=21521#p21521 <![CDATA[New add-on /VST Homing Pad]]> create your rhythms using a kick and a snare, Homing Pad is for you.
Homing Pad is a musical , creative and easy-to-use tool that allows you to generate grooves or melodies
in an instant and completely intuitive way.
And since nothing is more spontaneous than movement and gesture, Homing Pad uses this method
to allow you to explore rhythms that you otherwise would not have thought of.
So you say “ok, that is nice, but what is Homing Pad?”
A quick click here should satisfy your curiosity: Youtube link
Download in the add-on section and as VST on the free download page
More infos on the Wiki Page
Note : This patch/VST contains samples from Waveshaper kits
Statistics: Posted by nay-seven — 03 Oct 2011, 15:09
- CCQ -
