ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-12-14T18:53:33+01:00https://brainmodular.org/forums/app.php/feed/topic/31822011-12-14T18:53:33+01:002011-12-14T18:53:33+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=22093#p22093Statistics: Posted by yooha22 — 14 Dec 2011, 18:53
2011-12-12T22:14:43+01:002011-12-12T22:14:43+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=22079#p22079but Ill try to check and let you know...
edit: i think i replaced it by just /I (i like info caps)
you can see the new tagz in liveoscCallbacks.py if you wanna use V2 and update your tagz in your usine osc modules, cause i think it's easier that way than copy/paste stuff (possible), cause there are various stuff that i changed in LiveOsc.py too.. sorry for the mess, but when i tested, transfert time was highly reduced...
clipinfo should be now /I instead of /live/clip/info as you can see in callback file:
i didn't tried yet the new osc function senso just added, but it seems now an osc module is able to automatically detect what is received and create pins, maybe you can trigg clips or whatever you need from live and you'll get all the new tagz one shot!!... oO
]]>2011-12-12T17:24:39+01:002011-12-12T17:24:39+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=22078#p22078Sorry, a little off topic but...
I see you've done some changes to the liveOSCCallbacks.py file. The file no longer works with my setup as I use the reference /live/clip/info a lot, which you've removed/now done differently. I would like to utilise the loopall function, can you please let me know where I can find information about modifying my file to add it or point me to the part in which I can 'borrow' from yours?
Statistics: Posted by CreationFused — 12 Dec 2011, 17:24
]]>2011-12-07T23:01:43+01:002011-12-07T23:01:43+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=22014#p22014hopefully afer christmas i should have more free time and get back to my beloved usine, and work back on booth ableton and usine session patchs
]]>2011-12-06T05:44:37+01:002011-12-06T05:44:37+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=22004#p22004Statistics: Posted by loveandelectrik — 06 Dec 2011, 05:44
]]>2011-12-05T19:40:27+01:002011-12-05T19:40:27+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21998#p21998
oh yup, sure i will share it, but actually i got so much work... i don't think it will be out before a certain amount of time...
sounds good,hope you get some more time in the near future:)
]]>2011-12-02T19:20:13+01:002011-12-02T19:20:13+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21968#p21968Statistics: Posted by 23fx23 — 02 Dec 2011, 19:20
]]>2011-12-02T18:58:34+01:002011-12-02T18:58:34+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21967#p21967Statistics: Posted by ErotiCore SteNch — 02 Dec 2011, 18:58
]]>2011-11-25T21:57:34+01:002011-11-25T21:57:34+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21937#p21937 thanks
Statistics: Posted by yooha22 — 25 Nov 2011, 21:57
]]>2011-11-25T20:10:20+01:002011-11-25T20:10:20+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21936#p21936Statistics: Posted by 23fx23 — 25 Nov 2011, 20:10
]]>2011-11-25T18:56:21+01:002011-11-25T18:56:21+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21935#p21935 Cool luv it , yes it wont receive anything .
sorry for the delay.
Statistics: Posted by yooha22 — 25 Nov 2011, 18:56
]]>2011-11-19T00:27:31+01:002011-11-19T00:27:31+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21888#p21888 yupV2 was completely rebuild differently than v1. i think there were few scripting issues that where fixed, and the preload sytem is a different one, but TBH, i don't remember about v1...
sorry i don't understand, what do you mean by 'no osc in to control host?' mean if changing from live it doesn't update?
Pros :superfast response via Wifi , version one was a bit slow , did you change the modules or the layout only? v1 had some problems with input so there was 5 to 10 precent chance that when u touch your screen it would not follow your command . dunno if its usine or the patch . loved the box that let you choose your view and the zoom option same az actual Launchpad or Apc .
Cons :no osc in to control host ! and sometimes the connection was lost so no input to Ableton live.
Statistics: Posted by yooha22 — 18 Nov 2011, 23:55
]]>2011-11-16T22:19:33+01:002011-11-16T22:19:33+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21851#p21851 ill post the results soon .
Statistics: Posted by yooha22 — 16 Nov 2011, 22:19
]]>2011-11-16T14:43:39+01:002011-11-16T14:43:39+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21845#p21845sadly im unable to test/debug as i only got one computer, i hope it will work..
]]>2011-11-15T00:08:50+01:002011-11-15T00:08:50+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21839#p21839Statistics: Posted by yooha22 — 15 Nov 2011, 00:08
]]>2011-11-11T16:49:36+01:002011-11-11T16:49:36+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21808#p21808Statistics: Posted by 23fx23 — 11 Nov 2011, 16:49
]]>2011-11-02T14:53:38+01:002011-11-02T14:53:38+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21760#p21760
using an Acer W500 for remote control .
Statistics: Posted by yooha22 — 02 Nov 2011, 14:53
]]>2011-10-29T17:59:22+01:002011-10-29T17:59:22+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21727#p21727 like the idea of a usine only version:)
]]>2011-10-06T11:17:56+01:002011-10-06T11:17:56+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21573#p21573Statistics: Posted by ErotiCore SteNch — 06 Oct 2011, 12:17
]]>2011-10-02T20:20:02+01:002011-10-02T20:20:02+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=21513#p21513 as some might have seen, ive been totally overbusy recently and far from my beloved usine and the forum I will still have again a busy month to work.. but im still addict to usine no worries
So... ive reopen back my 8 months old APC files and had earth attack on the complexity of the stuff, tried to clean, make a bit simpler and update the stuff for a fresher V2.
So here is a beta (not as addon for now) working fine here. including only the new scalable Matrix based grid (all the rest is ready as in youtube vidz, but wanna clean and increment features slowly..) http://www.youtube.com/user/23fx232323# ... gf7nXyLGJ8
if some are interested, here is the patch with all needed osc files and instructions: i some test, let me know how it goes !
]]>BrainModularBrainModular Users Forum2011-12-14T18:53:33+01:00https://brainmodular.org/forums/app.php/feed/topic/31822011-12-14T18:53:33+01:002011-12-14T18:53:33+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=22093#p22093Statistics: Posted by yooha22 — 14 Dec 2011, 18:53
]]>2011-12-12T22:14:43+01:002011-12-12T22:14:43+01:00https://brainmodular.org/forums/viewtopic.php?t=3182&p=22079#p22079but Ill try to check and let you know...
