ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-09-20T12:30:55+01:00https://brainmodular.org/forums/app.php/feed/topic/31592011-09-20T12:30:55+01:002011-09-20T12:30:55+01:00https://brainmodular.org/forums/viewtopic.php?t=3159&p=21329#p21329 has a OSC menu.([Ctrl+F10]
Statistics: Posted by nay-seven — 20 Sep 2011, 13:30
]]>2011-09-20T12:22:47+01:002011-09-20T12:22:47+01:00https://brainmodular.org/forums/viewtopic.php?t=3159&p=21328#p21328Why easine hasn't osc config in the menu ?
Statistics: Posted by joffo78 — 20 Sep 2011, 13:22
]]>2011-09-20T09:16:33+01:002011-09-20T09:16:33+01:00https://brainmodular.org/forums/viewtopic.php?t=3159&p=21322#p21322your host is probably blocked?
]]>2011-09-20T09:08:22+01:002011-09-20T09:08:22+01:00https://brainmodular.org/forums/viewtopic.php?t=3159&p=21321#p21321Statistics: Posted by nay-seven — 20 Sep 2011, 10:08
2011-09-19T15:50:03+01:002011-09-19T15:50:03+01:00https://brainmodular.org/forums/viewtopic.php?t=3159&p=21311#p21311i did a vst plugins whitch control resolume by osc the patch works (when i use it in usine vst instance) but i send anything when i use it in vst version.
Statistics: Posted by joffo78 — 19 Sep 2011, 16:50
]]>BrainModularBrainModular Users Forum2011-09-20T12:30:55+01:00https://brainmodular.org/forums/app.php/feed/topic/31592011-09-20T12:30:55+01:002011-09-20T12:30:55+01:00https://brainmodular.org/forums/viewtopic.php?t=3159&p=21329#p21329 has a OSC menu.([Ctrl+F10]
]]>2011-09-19T15:50:03+01:002011-09-19T15:50:03+01:00https://brainmodular.org/forums/viewtopic.php?t=3159&p=21311#p21311i did a vst plugins whitch control resolume by osc the patch works (when i use it in usine vst instance) but i send anything when i use it in vst version.
