ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-09-08T18:36:18+01:00 https://brainmodular.org/forums/app.php/feed/topic/3123 2011-09-08T18:36:18+01:00 2011-09-08T18:36:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21130#p21130 <![CDATA[Usine 5.70.026 Update]]>
Can someone give a list (or at least an example) of what is "not nomally stored in preset manager"? I thought the PMs stored everything.....
Statistics: Posted by woodslanding — 08 Sep 2011, 19:36
2011-09-07T17:45:36+01:00 2011-09-07T17:45:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21123#p21123 <![CDATA[Usine 5.70.026 Update]]>
Can you confirm thant it does not take any cpu power at all ?
Thanks.
Statistics: Posted by Len — 07 Sep 2011, 18:45
2011-09-07T17:19:11+01:00 2011-09-07T17:19:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21122#p21122 <![CDATA[Usine 5.70.026 Update]]>
Event thru : what a good news !
Please make also Array and String thru
this module works also with Array's and strings!
Statistics: Posted by senso — 07 Sep 2011, 18:19
2011-09-07T17:12:33+01:00 2011-09-07T17:12:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21121#p21121 <![CDATA[Usine 5.70.026 Update]]>
A really good way to organize connection points.
Statistics: Posted by Len — 07 Sep 2011, 18:12
2011-09-06T08:19:54+01:00 2011-09-06T08:19:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21109#p21109 <![CDATA[Usine 5.70.026 Update]]>
Statistics: Posted by caco — 06 Sep 2011, 09:19
2011-09-06T07:58:31+01:00 2011-09-06T07:58:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21108#p21108 <![CDATA[Usine 5.70.026 Update]]> event thru
@woodslanding
this add a percentage position ( left and top defined in percent ([0..1]) of the parent panel size. ) , check IML
Statistics: Posted by nay-seven — 06 Sep 2011, 08:58
2011-09-06T03:56:30+01:00 2011-09-06T03:56:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21106#p21106 <![CDATA[Usine 5.70.026 Update]]>
One question:
- new SET_CTRL_POS_PC Internal Messages Language (IML) command
What does the PC stand for?
Statistics: Posted by woodslanding — 06 Sep 2011, 04:56
2011-09-05T23:22:24+01:00 2011-09-05T23:22:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21104#p21104 <![CDATA[Usine 5.70.026 Update]]> Last Changes
Statistics: Posted by Floego — 06 Sep 2011, 00:22
2011-09-05T22:42:58+01:00 2011-09-05T22:42:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21102#p21102 <![CDATA[Usine 5.70.026 Update]]> And what is the event thru module ?
Statistics: Posted by joffo78 — 05 Sep 2011, 23:42
2011-09-05T21:01:48+01:00 2011-09-05T21:01:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3123&p=21100#p21100 <![CDATA[Usine 5.70.026 Update]]> Few improvements and bugs fixed in this release.
improvements
- new Event thru module
- new bitmap inlet in the Container module
- new SET_CTRL_SIZE_PC Internal Messages Language (IML) command
- new smooth option in Quadratic distance 2D module.
- new Kalman filter script for data filtering.
fixed bugs
- Random Data bad initialization when synchro = play button
- Send Usine Internal Messages doesn’t work properly in poly sub-patches
- OSC (Open Sound Control) Setup deactivated in the Usine Stage version
Statistics: Posted by senso — 05 Sep 2011, 22:01
Thanks.
@woodslanding
One question:
improvements
fixed bugs
