2011-09-02T17:20:57+02:002011-09-02T17:20:57+02:00https://brainmodular.org/forums/viewtopic.php?t=3112&p=21063#p21063(hoewer the scale has to be in -1...1 range as interpreted as audio, but you can use change scale patch to fit in/ out )
Statistics: Posted by nay-seven — 31 Aug 2011, 09:40
]]>2011-08-31T09:04:44+02:002011-08-31T09:04:44+02:00https://brainmodular.org/forums/viewtopic.php?t=3112&p=21034#p21034Is it possible to record and restitue the modulation of an array contain. For example i put an array in a "recorder" and another on out. when i change the values of the first there are recorded and i can play there after with the other.
Statistics: Posted by joffo78 — 31 Aug 2011, 09:04
]]>BrainModularBrainModular Users Forum2011-09-04T19:58:24+02:00https://brainmodular.org/forums/app.php/feed/topic/31122011-09-04T19:58:24+02:002011-09-04T19:58:24+02:00https://brainmodular.org/forums/viewtopic.php?t=3112&p=21084#p21084Statistics: Posted by joffo78 — 04 Sep 2011, 19:58
]]>2011-09-02T17:20:57+02:002011-09-02T17:20:57+02:00https://brainmodular.org/forums/viewtopic.php?t=3112&p=21063#p21063(hoewer the scale has to be in -1...1 range as interpreted as audio, but you can use change scale patch to fit in/ out )
