]]>2011-08-30T07:35:25+01:002011-08-30T07:35:25+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21020#p21020and it's certainly better if it's you who post on the Renoise forum..?
about midi , yes with a virtual midi drivers no problems and more easy for you to send informations to renoise..?
Statistics: Posted by nay-seven — 30 Aug 2011, 08:35
]]>2011-08-29T23:29:29+01:002011-08-29T23:29:29+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21018#p21018 i HAVE to use OSC to control renoise from usine right i cant use midi ???
]]>2011-08-29T22:11:51+01:002011-08-29T22:11:51+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21017#p21017will test some more tommorow its bedtime soon
Can you link this thread back to the admin so he can post here? Is the replier the developer?
OSC works with dozens of other configs and controllers that I know of. I can't test Usine because I'm on OSX and there doesn't appear to be a Mac version. Here's a python example. Here's the code that does note_on in that package.
OSC is a standard like HTML is a standard. It takes a lot of fiddling around to get it to "do what you want", it's not necessarily trivial or the same for everyone.
]]>2011-08-29T21:07:31+01:002011-08-29T21:07:31+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21016#p21016I've use a fresh empty song in renoise and double click on a sample in usine I've use a trunc module on parameters 3 ( note number ) and Renoise react
Statistics: Posted by nay-seven — 29 Aug 2011, 22:07
]]>2011-08-29T20:58:56+01:002011-08-29T20:58:56+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21015#p21015so I've this message /trigger/note_on with 4 arguments so no more rejected but no results too...
Statistics: Posted by nay-seven — 29 Aug 2011, 21:58
]]>2011-08-29T20:45:44+01:002011-08-29T20:45:44+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21014#p21014i've also test in integer or array mode , same results...
Statistics: Posted by nay-seven — 29 Aug 2011, 21:45
]]>2011-08-29T20:37:28+01:002011-08-29T20:37:28+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21013#p21013 thanks for your efforts,yeah i also kept getting those REJECTED messages
i have posted on the renoise forum and linked to this topic hopefully they can look into it
]]>2011-08-29T20:28:16+01:002011-08-29T20:28:16+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21012#p21012I've test quickly using the message give in the renoise manual here for example to send note one
Trigger a Note-On. arg#1: instrument (-1 for the currently selected one) arg#2: track (-1 for the current one) arg#3: note value (0-119) arg#4: velocity (0-127)
but I've always a message like this in renoise OSC console /trigger/note_on/ with 4 arguments (REJECTED) maybe you have to ask on renoise forum or maybe there's some renoise users here
Statistics: Posted by nay-seven — 29 Aug 2011, 21:28
]]>2011-08-29T16:58:22+01:002011-08-29T16:58:22+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21011#p21011Statistics: Posted by ErotiCore SteNch — 29 Aug 2011, 17:58
2011-08-29T16:11:22+01:002011-08-29T16:11:22+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21010#p21010Statistics: Posted by nay-seven — 29 Aug 2011, 17:11
]]>2011-08-29T14:58:27+01:002011-08-29T14:58:27+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21009#p21009Statistics: Posted by ErotiCore SteNch — 29 Aug 2011, 15:58
]]>2011-08-29T14:56:39+01:002011-08-29T14:56:39+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21008#p21008Using OSC then i suppose you have to refer to Renoise manual to set receive port and address have you yet work with OSC or..?
Statistics: Posted by nay-seven — 29 Aug 2011, 15:56
]]>2011-08-29T14:05:05+01:002011-08-29T14:05:05+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21007#p21007 something i need to control is the /renoise/transport/start and the //renoise/transport/stop
and some other smaller things,i looked around but i really cant get my head around how i connect usine to renoise via OSC so i can control renoise parameters in usine
can anyone give some hints or if theres a small tutorial somewhere that shows how to set this up?
]]>2011-08-29T16:11:22+01:002011-08-29T16:11:22+01:00https://brainmodular.org/forums/viewtopic.php?t=3109&p=21010#p21010Statistics: Posted by nay-seven — 29 Aug 2011, 17:11
