ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-11-02T10:01:00+02:00https://brainmodular.org/forums/app.php/feed/topic/30972012-11-02T10:01:00+02:002012-11-02T10:01:00+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24709#p24709Statistics: Posted by noise2sine — 02 Nov 2012, 09:01
2012-10-30T17:42:21+02:002012-10-30T17:42:21+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24681#p24681Statistics: Posted by noise2sine — 30 Oct 2012, 16:42
]]>2012-10-30T17:38:06+02:002012-10-30T17:38:06+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24680#p246801_Add a pass if change module between the list box and the conductor 2_right click on the list box and choose : not saved in the conductor
Statistics: Posted by nay-seven — 30 Oct 2012, 16:38
Statistics: Posted by noise2sine — 30 Oct 2012, 15:41
]]>2012-10-30T12:29:35+02:002012-10-30T12:29:35+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24676#p24676btw, i found a simplest solution and really more friendly to manage this,i think Each midi out has his own fader to select the program change number, set it as you need and just press the rewrite button. i've also link the name of the preset to a list box Download you'll tell me if it can be ok for you
Statistics: Posted by nay-seven — 30 Oct 2012, 11:29
]]>2012-10-30T11:18:38+02:002012-10-30T11:18:38+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24674#p24674Statistics: Posted by noise2sine — 30 Oct 2012, 10:18
]]>2012-10-30T09:57:50+02:002012-10-30T09:57:50+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24673#p24673have you patch this way..?
Statistics: Posted by nay-seven — 30 Oct 2012, 08:57
]]>2012-10-30T09:45:58+02:002012-10-30T09:45:58+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24672#p24672 Unfortunatly it's not working ...
Statistics: Posted by noise2sine — 30 Oct 2012, 08:45
]]>2012-10-29T10:11:17+02:002012-10-29T10:11:17+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24661#p24661strings to integer module.
Statistics: Posted by nay-seven — 29 Oct 2012, 09:11
]]>2012-10-29T10:03:41+02:002012-10-29T10:03:41+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24659#p24659 when i'm using this patch i always have a +1 value . If i want to program change 26 and write 26 in the list, the program change that will be selected will be 27 . Where is the best place for using a x-1 module in the patch ?
Statistics: Posted by noise2sine — 29 Oct 2012, 09:03
]]>2012-10-24T17:02:39+02:002012-10-24T17:02:39+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24628#p24628Statistics: Posted by nay-seven — 24 Oct 2012, 17:02
]]>2012-10-24T16:06:48+02:002012-10-24T16:06:48+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24627#p24627Statistics: Posted by noise2sine — 24 Oct 2012, 16:06
]]>2012-10-24T15:43:03+02:002012-10-24T15:43:03+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24626#p24626 change the selector open the script change the line const NB_ELEMENTS = 8; to = 30 and CTRL+F9 to compile change the polyphony of the sub patch to 30 and apply and maybe other to check
Statistics: Posted by nay-seven — 24 Oct 2012, 15:43
]]>2012-10-24T15:35:28+02:002012-10-24T15:35:28+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24625#p24625Statistics: Posted by noise2sine — 24 Oct 2012, 15:35
]]>2012-10-24T15:13:42+02:002012-10-24T15:13:42+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24624#p24624Values of the first selection is done by his list box , click the button Edit Scene 0 to choose the numbers for this scene for example , if your list box say 1 8 3 scene 0, will send PC 1 for vsti1 PC 8 for vsti2 PC 3 for vsti3
Statistics: Posted by nay-seven — 24 Oct 2012, 15:13
]]>2012-10-24T14:29:44+02:002012-10-24T14:29:44+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24623#p24623Statistics: Posted by noise2sine — 24 Oct 2012, 14:29
]]>2012-10-24T14:25:50+02:002012-10-24T14:25:50+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24622#p24622Statistics: Posted by nay-seven — 24 Oct 2012, 14:25
]]>2012-10-24T13:54:40+02:002012-10-24T13:54:40+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24621#p24621 I'm sorry but i need the patch you made concerning changing program change with the conductor, but i have no clue at all about how is working ! i have tested it long time ago ....
Thank you
Statistics: Posted by noise2sine — 24 Oct 2012, 13:54
]]>2011-08-26T18:08:47+02:002011-08-26T18:08:47+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=20964#p20964add a new string to integer set the polyphony of the sub patch to 4 and apply ( maybe you 'll have to reconnect modules) and finally add a new midi out
Statistics: Posted by nay-seven — 26 Aug 2011, 18:08
Statistics: Posted by nay-seven — 26 Aug 2011, 09:02
]]>2011-08-26T08:00:57+02:002011-08-26T08:00:57+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=20944#p20944download check this tutorial to add link or pictures if needed : Here
Statistics: Posted by nay-seven — 26 Aug 2011, 08:00
Statistics: Posted by nay-seven — 25 Aug 2011, 23:23
]]>2011-08-25T21:54:40+02:002011-08-25T21:54:40+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=20930#p20930Statistics: Posted by bsork — 25 Aug 2011, 21:54
]]>BrainModularBrainModular Users Forum2012-11-02T10:01:00+02:00https://brainmodular.org/forums/app.php/feed/topic/30972012-11-02T10:01:00+02:002012-11-02T10:01:00+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24709#p24709Statistics: Posted by noise2sine — 02 Nov 2012, 09:01
]]>2012-10-30T17:42:21+02:002012-10-30T17:42:21+02:00https://brainmodular.org/forums/viewtopic.php?t=3097&p=24681#p24681Statistics: Posted by noise2sine — 30 Oct 2012, 16:42
Thank you
