ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-01-07T20:39:43+01:00 https://brainmodular.org/forums/app.php/feed/topic/3041 2013-01-07T20:39:43+01:00 2013-01-07T20:39:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25175#p25175 <![CDATA[donwload problems]]> Statistics: Posted by r.erorr — 07 Jan 2013, 20:39
2013-01-07T20:13:39+01:00 2013-01-07T20:13:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25174#p25174 <![CDATA[donwload problems]]> Statistics: Posted by nay-seven — 07 Jan 2013, 20:13
2013-01-07T19:57:03+01:00 2013-01-07T19:57:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25173#p25173 <![CDATA[donwload problems]]>
Not Found
The requested URL /download/tmp777021897/Usine Hollyhock will be available soon, please come back later was not found on this server.
- any ideas why?
Statistics: Posted by r.erorr — 07 Jan 2013, 19:57
2013-01-05T22:59:31+01:00 2013-01-05T22:59:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25170#p25170 <![CDATA[donwload problems]]> i thought so that the error may be something more complex. since i got either mysql connection errors, internal server errors, file not found (the path to /tmpXYZ) or another error (sorry forgot what it was).
good luck!
I'll recheck this forum here when to try again ;)
Statistics: Posted by lodsb — 05 Jan 2013, 22:59
2013-01-05T22:37:05+01:00 2013-01-05T22:37:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25169#p25169 <![CDATA[donwload problems]]> Actually, it's not easy to solve for us, because the symptoms are never exactly the same
one tip : don't try several times in a short delay cause it saturate the server more..
Statistics: Posted by nay-seven — 05 Jan 2013, 22:37
2013-01-05T19:27:48+01:00 2013-01-05T19:27:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25168#p25168 <![CDATA[donwload problems]]> Statistics: Posted by lodsb — 05 Jan 2013, 19:27
2012-12-27T21:38:48+01:00 2012-12-27T21:38:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25139#p25139 <![CDATA[donwload problems]]> Sorry for this inconvenience, there's some slowdown recently and we work on it
can you please try again in 1 hour or 2 ?
Statistics: Posted by nay-seven — 27 Dec 2012, 21:38
2012-12-27T21:22:33+01:00 2012-12-27T21:22:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=25138#p25138 <![CDATA[donwload problems]]>
Website menu 'about-contact' does not respond either ...
tried between 21:00 and 21:20 on 27.12.12
mcpman
Statistics: Posted by mcpman — 27 Dec 2012, 21:22
2011-12-19T19:58:07+01:00 2011-12-19T19:58:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=22145#p22145 <![CDATA[donwload problems]]> Statistics: Posted by visuality — 19 Dec 2011, 19:58
2011-08-10T07:08:43+01:00 2011-08-10T07:08:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=20554#p20554 <![CDATA[donwload problems]]> Statistics: Posted by nay-seven — 10 Aug 2011, 08:08
2011-08-10T01:35:03+01:00 2011-08-10T01:35:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=20553#p20553 <![CDATA[donwload problems]]> so i've downloaded the last version without problem
i'll reinstall my browser that's all you might have other things to do more important
sorry to annoy you
thanks
Regards :D
Statistics: Posted by waolelaid — 10 Aug 2011, 02:35
2011-08-09T16:05:10+01:00 2011-08-09T16:05:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=20536#p20536 <![CDATA[donwload problems]]>
Statistics: Posted by waolelaid — 09 Aug 2011, 17:05
2011-08-09T16:00:01+01:00 2011-08-09T16:00:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=20533#p20533 <![CDATA[donwload problems]]> Statistics: Posted by senso — 09 Aug 2011, 17:00
2011-08-09T15:57:27+01:00 2011-08-09T15:57:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=3041&p=20532#p20532 <![CDATA[donwload problems]]> easine pro 5.70 vst-i.dll ; easine pro 5.70 vst.dll but when i try to download bigger files as "standalone"
i receive both 2 messages
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, postmaster@www.sensomusic.org and inform them of the time the error occurred, and anything you might have done that may have caused the error. (it happens since the RC01 and i didn't do any thing or changes on the PC)
More information about this error may be available in the server error log. (i don't know where is "server error log")
i don't understand what happen
if you can tell me
Thank you in advance
Statistics: Posted by waolelaid — 09 Aug 2011, 16:57
Not Found
- any ideas why?
good luck!
mcpman
sorry to annoy you
thanks
Regards :D
if you can tell me
