ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-08-10T20:50:10+02:00 https://brainmodular.org/forums/app.php/feed/topic/3039 2011-08-10T20:50:10+02:00 2011-08-10T20:50:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=3039&p=20592#p20592 <![CDATA[how to make a loop ?]]> Statistics: Posted by Floego — 10 Aug 2011, 20:50
2011-08-09T22:50:56+02:00 2011-08-09T22:50:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=3039&p=20551#p20551 <![CDATA[how to make a loop ?]]>
To feed values into arrays, you can use the set array value module but I've been using a different trick. I load the value directly into one of the array fader positions (fader out + new value + fader in - pass if changed) and use the 'roll array' module to push it down one. Then take the output (in my case a MIDI note value) on the next fader position. This gives me a loop with immediate feedback.
Is this like what you're looking for or do I misunderstand?
- CCQ -
Statistics: Posted by CleverConQueso — 09 Aug 2011, 22:50
2011-08-09T16:47:06+02:00 2011-08-09T16:47:06+02:00 https://brainmodular.org/forums/viewtopic.php?t=3039&p=20530#p20530 <![CDATA[how to make a loop ?]]> count millisecondes you can maybe tweak
there's also some counter patch examples..
Statistics: Posted by nay-seven — 09 Aug 2011, 16:47
2011-08-09T16:28:46+02:00 2011-08-09T16:28:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=3039&p=20523#p20523 <![CDATA[how to make a loop ?]]> Example:
I push a button, a process is triggered N times which results in... feeling an array with special values, for instance.
Would you advice me to use pascal/script ?
Statistics: Posted by protofuse — 09 Aug 2011, 16:28
2011-08-09T16:16:16+02:00 2011-08-09T16:16:16+02:00 https://brainmodular.org/forums/viewtopic.php?t=3039&p=20521#p20521 <![CDATA[how to make a loop ?]]> Statistics: Posted by nay-seven — 09 Aug 2011, 16:16
2011-08-09T16:03:22+02:00 2011-08-09T16:03:22+02:00 https://brainmodular.org/forums/viewtopic.php?t=3039&p=20520#p20520 <![CDATA[how to make a loop ?]]>
I want to make a loop. (like the max objects uzi + counter)
I cannot find the right object.
anyone?
Statistics: Posted by protofuse — 09 Aug 2011, 16:03
- CCQ -
anyone?
