ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-08-04T16:49:37+01:00 https://brainmodular.org/forums/app.php/feed/topic/3011 2011-08-04T16:49:37+01:00 2011-08-04T16:49:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=3011&p=20333#p20333 <![CDATA[a very basic groove box]]> i'd just upload a new version where the numbre of step of each parameters follows the cycle lengh
try to compare to modify de lengh of the cycle
Statistics: Posted by joffo78 — 04 Aug 2011, 17:49
2011-08-04T16:15:59+01:00 2011-08-04T16:15:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=3011&p=20331#p20331 <![CDATA[a very basic groove box]]> I doubt I'll understand a lot of the work that is probably in this, but hopefully that will change over the coming months.
Thanks for this joffo78, a real inspiration for me.:)
Statistics: Posted by AstralV66 — 04 Aug 2011, 17:15
2011-08-04T15:57:36+01:00 2011-08-04T15:57:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=3011&p=20330#p20330 <![CDATA[a very basic groove box]]> mr groove box 01
now you can record anything and apply a slice detection .
you can also see a video demo on this channel :
http://www.youtube.com/user/jeanfr011275
regards
Statistics: Posted by joffo78 — 04 Aug 2011, 16:57
2011-08-03T09:00:30+01:00 2011-08-03T09:00:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=3011&p=20262#p20262 <![CDATA[a very basic groove box]]> quick test : little problem at first with the delay, give me some bad sounds when i open
suggestion: textfield as name of each part , can also be a on/off switch , easy to mute quickly some parts..?
will check deeper later
but thanks, it's a good addon
number of download are only visible in stats actually
Statistics: Posted by nay-seven — 03 Aug 2011, 10:00
2011-08-03T08:30:29+01:00 2011-08-03T08:30:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=3011&p=20259#p20259 <![CDATA[a very basic groove box]]> if you're beginners have a look of my simple groove box i made very simply:
http://www.sensomusic.com/downloadaddon ... OVEBOX.pat.
Is it possible to get the number of download for the addons ?
Statistics: Posted by joffo78 — 03 Aug 2011, 09:30
regards
