Statistics: Posted by nay-seven — 03 Aug 2011, 11:32
]]>2011-08-03T09:25:24+01:002011-08-03T09:25:24+01:00https://brainmodular.org/forums/viewtopic.php?t=3010&p=20263#p20263 If this works, you can add it to the patch either with connections or using IML. With connections, I guess you'd need to have a WaitOne or two before turning the objects back on, but with IML messages, I guess you can skip that part.
]]>2011-08-03T07:25:23+01:002011-08-03T07:25:23+01:00https://brainmodular.org/forums/viewtopic.php?t=3010&p=20257#p20257works only for Usine interface objects.
Statistics: Posted by nay-seven — 03 Aug 2011, 08:25
]]>2011-08-02T20:12:32+01:002011-08-02T20:12:32+01:00https://brainmodular.org/forums/viewtopic.php?t=3010&p=20247#p20247Statistics: Posted by nay-seven — 02 Aug 2011, 21:12
]]>2011-08-02T19:49:52+01:002011-08-02T19:49:52+01:00https://brainmodular.org/forums/viewtopic.php?t=3010&p=20246#p20246I am trying to add multi touch ability to a VST PLUGIN by mapping its controls to Usine faders and buttons(midi). I put the plugin in "control panel" (not standalone window). Now i try to cover its interface by panels and buttons while leaving some information areas uncovered. It works fine till program restart. All buttons and faders are now hidden by vst interface. QUESTION: How to make elements be ALWAYS on top?
]]>BrainModularBrainModular Users Forum2011-08-03T11:14:15+01:00https://brainmodular.org/forums/app.php/feed/topic/30102011-08-03T11:14:15+01:002011-08-03T11:14:15+01:00https://brainmodular.org/forums/viewtopic.php?t=3010&p=20267#p20267Statistics: Posted by Be4Be2 — 03 Aug 2011, 12:14
]]>2011-08-03T10:32:01+01:002011-08-03T10:32:01+01:00https://brainmodular.org/forums/viewtopic.php?t=3010&p=20266#p20266works perfectly :
