ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-08-05T17:44:55+01:00https://brainmodular.org/forums/app.php/feed/topic/30082011-08-05T17:44:55+01:002011-08-05T17:44:55+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20396#p20396Statistics: Posted by protofuse — 05 Aug 2011, 18:44
2011-08-05T17:43:26+01:002011-08-05T17:43:26+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20395#p20395Statistics: Posted by Floego — 05 Aug 2011, 18:43
]]>2011-08-05T17:43:18+01:002011-08-05T17:43:18+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20394#p20394http://sensomusic.com/download/ sdk 5.7 is released ... !!!!
next?!
Statistics: Posted by protofuse — 05 Aug 2011, 18:43
]]>2011-08-05T17:40:11+01:002011-08-05T17:40:11+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20393#p20393Statistics: Posted by ErotiCore SteNch — 05 Aug 2011, 18:40
]]>2011-08-05T17:36:48+01:002011-08-05T17:36:48+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20391#p20391
yes, the release candidate is will arrive today!
Statistics: Posted by protofuse — 05 Aug 2011, 18:36
]]>2011-08-05T17:36:29+01:002011-08-05T17:36:29+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20389#p20389Statistics: Posted by senso — 05 Aug 2011, 18:36
]]>2011-08-05T17:33:39+01:002011-08-05T17:33:39+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20388#p20388 Can we hope to see usine 5.70 next days?:)
Statistics: Posted by headphoner — 05 Aug 2011, 18:33
]]>2011-08-04T18:59:08+01:002011-08-04T18:59:08+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20336#p20336Statistics: Posted by Sasu Honka — 04 Aug 2011, 19:59
]]>2011-08-03T18:51:46+01:002011-08-03T18:51:46+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20301#p20301Statistics: Posted by lalo — 03 Aug 2011, 19:51
]]>2011-08-03T18:50:52+01:002011-08-03T18:50:52+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20300#p20300i'm on a single core cpu a.
]]>2011-08-03T17:55:55+01:002011-08-03T17:55:55+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20297#p20297multicore support in Live (even Live doesn't work well. did you try to disable it ? It can produce very different results.
Statistics: Posted by protofuse — 03 Aug 2011, 18:55
]]>2011-08-03T17:08:25+01:002011-08-03T17:08:25+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20295#p20295but usine works flawlessly
]]>2011-08-03T17:07:39+01:002011-08-03T17:07:39+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20294#p20294still very hi on cpu and full of clicks.
]]>2011-08-03T17:02:00+01:002011-08-03T17:02:00+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20293#p20293like the 7th, it still works very fine here http://designthemedia.com/public/ok.mp4
Statistics: Posted by protofuse — 03 Aug 2011, 18:02
]]>2011-08-03T16:53:54+01:002011-08-03T16:53:54+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20292#p20292 Demo Exported VST 08 (just a beta).dll lalo, cause don't see this bug anymore now and works fine here with Live 8.2 / old dual core 1,8
Statistics: Posted by nay-seven — 03 Aug 2011, 17:53
fast & not sluggish in Live 8.2.2 on my win7 64 bits (core i7)
cannot wait for testing the export here!! (I'd like to know about the "first installation" process. Will it be necessary on each patch ? just to know. NI stuff installs A BUNCH of stuff and it is VERY ok!)
maybe is optimized for multicore system ( mine is single 32bit ) tried on Ableton Live 8.2.2 same problems...even worse.
if you open a easine menu you cant close it using the normal "x" on the top-right of the window. you have to click again in the easine menu where the window has its "open" command".
]]>2011-08-03T14:04:14+01:002011-08-03T14:04:14+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20279#p20279Statistics: Posted by Sasu Honka — 03 Aug 2011, 15:04
]]>2011-08-03T12:45:46+01:002011-08-03T12:45:46+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20275#p20275Statistics: Posted by 23fx23 — 03 Aug 2011, 13:45
]]>2011-08-03T11:51:27+01:002011-08-03T11:51:27+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20269#p20269 cannot wait for testing the export here!! (I'd like to know about the "first installation" process. Will it be necessary on each patch ? just to know. NI stuff installs A BUNCH of stuff and it is VERY ok!)
Statistics: Posted by protofuse — 03 Aug 2011, 12:51
]]>2011-08-03T11:45:23+01:002011-08-03T11:45:23+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20268#p20268tried the exported vst teasine... seems quite heavy on cpu ( 90 % cpu peaks ) and the interface seems quite sluggish. at least on reaper 4.0 rc4 on my windows7 machine ( pretty old but use to run perfectly usine as a standalone )
]]>2011-08-03T08:54:49+01:002011-08-03T08:54:49+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20261#p20261I guess those who are used to share their work will continue and it is quite possible to share the source with its VST ..
Statistics: Posted by nay-seven — 03 Aug 2011, 09:54
]]>2011-08-03T08:43:03+01:002011-08-03T08:43:03+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20260#p20260Statistics: Posted by gurulogic — 03 Aug 2011, 09:43
]]>2011-08-03T08:27:19+01:002011-08-03T08:27:19+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20258#p20258don't you afraid with this fabulous export vst functiun that members will only upload addons in vst only ? In this case the principla of usine won't be as open than yet because which is interesting is modify addons...
Statistics: Posted by joffo78 — 03 Aug 2011, 09:27
]]>BrainModularBrainModular Users Forum2011-08-05T17:44:55+01:00https://brainmodular.org/forums/app.php/feed/topic/30082011-08-05T17:44:55+01:002011-08-05T17:44:55+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20396#p20396Statistics: Posted by protofuse — 05 Aug 2011, 18:44
]]>2011-08-05T17:43:26+01:002011-08-05T17:43:26+01:00https://brainmodular.org/forums/viewtopic.php?t=3008&p=20395#p20395Statistics: Posted by Floego — 05 Aug 2011, 18:43
next?!
