ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-03-09T11:47:36+01:00 https://brainmodular.org/forums/app.php/feed/topic/293 2007-03-09T11:47:36+01:00 2007-03-09T11:47:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=293&p=1426#p1426 <![CDATA[Script variables and the preset manager]]>
And you're very right in that it's not a priority!
Statistics: Posted by bsork — 09 Mar 2007, 11:47
2007-03-09T09:17:17+01:00 2007-03-09T09:17:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=293&p=1425#p1425 <![CDATA[Script variables and the preset manager]]>
Doable I suppose, but probably a mess to program...
a nightmare do you mean?
But I can add some 'file' functions in the script to store your data's your self in a separate file:
like
openfile('data.dat');
writeInfile(data1)
closefile;
but later, it's not a priority?
Statistics: Posted by senso — 09 Mar 2007, 09:17
2007-03-09T08:50:02+01:00 2007-03-09T08:50:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=293&p=1423#p1423 <![CDATA[Script variables and the preset manager]]>
Well, it was just an idea for an improved XY-morph patch. I have other ideas though.
Statistics: Posted by bsork — 09 Mar 2007, 08:50
2007-03-08T23:17:18+01:00 2007-03-08T23:17:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=293&p=1417#p1417 <![CDATA[Script variables and the preset manager]]>
Statistics: Posted by Guest — 08 Mar 2007, 23:17
2007-03-08T16:59:08+01:00 2007-03-08T16:59:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=293&p=1412#p1412 <![CDATA[Script variables and the preset manager]]> internal script data's aren't stored in the preset manager.
Only inlet, outlet values.
use an external Array module to store data's.
Statistics: Posted by senso — 08 Mar 2007, 16:59
2007-03-08T09:51:55+01:00 2007-03-08T09:51:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=293&p=1407#p1407 <![CDATA[Script variables and the preset manager]]>
I can't just figure out what is happening to variables in a script when storing and recalling a patch using the preset manager. I've been trying to loop through the presets to put the values from a single array module into arrays within a script as a sort of update procedure.
Statistics: Posted by bsork — 08 Mar 2007, 09:51
like
writeInfile(data1)
closefile;
