ArrayArrayArray BrainModular BrainModular Users Forum 2011-06-24T22:26:02+01:00 https://brainmodular.org/forums/app.php/feed/topic/2916 2011-06-24T22:26:02+01:00 2011-06-24T22:26:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=2916&p=19742#p19742 <![CDATA[Multiple Audio Inputs to a Patch - Performance Issues]]> I redid the patch to test it out and although it took me a while to get the graphical elements sorted, (I was trying to put the duplicated controls inside of the polyphonic sub-patch) now I see what you mean. I'll test and see if this clears those 'Internal Error' messages I was getting.
Polyphonic Mixer
Whenever I think I've learned Usine, more features are revealed.
- CCQ -
Statistics: Posted by CleverConQueso — 24 Jun 2011, 23:26
2011-06-24T11:26:24+01:00 2011-06-24T11:26:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=2916&p=19733#p19733 <![CDATA[Multiple Audio Inputs to a Patch - Performance Issues]]> You are typically in the case where you can use the sub-patches polyphony because tour 8 tracks a identical. You'll probably save cpu applying 8 for poly.
ps: nice design!
edit: after a test with poly and the selector replaced with simple audio volumes :your patch is now 1% cpu.. 50% more efficient...
Statistics: Posted by senso — 24 Jun 2011, 12:26
2011-06-16T22:38:56+01:00 2011-06-16T22:38:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=2916&p=19646#p19646 <![CDATA[Multiple Audio Inputs to a Patch - Performance Issues]]>
I'm going to play around with the audio buses to see if they make the performance issue go away, but practically speaking, drag and drop inputs would be easiest. I was looking at the 'Additional Audio Inputs' but I just don't get it. Is there a way to wire them that would allow many inputs to a patch and address the performance issue?
The GUI-
The Patch
Patch
Thanks all,
- CCQ -
Statistics: Posted by CleverConQueso — 16 Jun 2011, 23:38
Polyphonic Mixer
- CCQ -
ps: nice design!
The GUI-
The Patch
Patch
Thanks all,
- CCQ -
