ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-06-15T10:44:13+01:00 https://brainmodular.org/forums/app.php/feed/topic/2905 2011-06-15T10:44:13+01:00 2011-06-15T10:44:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19635#p19635 <![CDATA[OSC between two PC's]]>
I am now receiving two lots of messages, one from ableton's IP (192.168.2.4) and the other is from the 127.1.1.1 IP. Not sure if its meant to be doing that!
Statistics: Posted by CreationFused — 15 Jun 2011, 11:44
2011-06-10T20:06:43+01:00 2011-06-10T20:06:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19589#p19589 <![CDATA[OSC between two PC's]]>
i was about to post the answer when i saw you answered scrolling, yup need to edit python files normally,
btw i was never able to test, so report how it goes..
Statistics: Posted by 23fx23 — 10 Jun 2011, 21:06
2011-06-10T17:22:17+01:00 2011-06-10T17:22:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19587#p19587 <![CDATA[OSC between two PC's]]>
I owe you beers also! (more than one)
Statistics: Posted by CreationFused — 10 Jun 2011, 18:22
2011-06-10T16:02:17+01:00 2011-06-10T16:02:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19586#p19586 <![CDATA[OSC between two PC's]]>
If wanna run in Remote Mode (different computers):
Put the swich on left on "Remote", enter target computer
(the one live runs on) IP or name bellow.
then you need to specify liveOSC server to send to Usine Host Computer.
for that edit the liveOSC.py file found in liveOSC folder and find
self.oscServer = RemixNet.OSCServer('localhost')
replace 'local host' by Usine computer IP. ie( '192.168.1.32')
I've use Notepad++ to edit the py file,
so i've now:
self.oscServer = RemixNet.OSCServer('192.168.1.3')
works for me...
@23FX you owe me a beer ...;)
Statistics: Posted by nay-seven — 10 Jun 2011, 17:02
2011-06-10T14:51:18+01:00 2011-06-10T14:51:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19585#p19585 <![CDATA[OSC between two PC's]]> Statistics: Posted by CreationFused — 10 Jun 2011, 15:51
2011-06-10T14:19:28+01:00 2011-06-10T14:19:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19582#p19582 <![CDATA[OSC between two PC's]]> maybe there's a kind of broadcast filter in the Live script..?
Statistics: Posted by nay-seven — 10 Jun 2011, 15:19
2011-06-10T14:08:28+01:00 2011-06-10T14:08:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19581#p19581 <![CDATA[OSC between two PC's]]>
Could there be any lag in relation to porting it through a local usine?
Statistics: Posted by CreationFused — 10 Jun 2011, 15:08
2011-06-10T12:39:25+01:00 2011-06-10T12:39:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19579#p19579 <![CDATA[OSC between two PC's]]> but i've the same problem with 2 computers,
works between 2 Usine instance, but don't receive anything from live on the second computer..
the only i 've found:
send in local to Usine, and from Usine 1 send to computer2/usine2...:rolleyes:
have to move right now, will try again later
Statistics: Posted by nay-seven — 10 Jun 2011, 13:39
2011-06-10T11:21:13+01:00 2011-06-10T11:21:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19578#p19578 <![CDATA[OSC between two PC's]]>
Yep, port set to 9001.
Statistics: Posted by CreationFused — 10 Jun 2011, 12:21
2011-06-10T11:18:53+01:00 2011-06-10T11:18:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19577#p19577 <![CDATA[OSC between two PC's]]> but it's now recognized as a remote midi surface..?
so do i need to activate some midi in and out..? confused by the way Live works..
second question the remote port is 9001 as in the 23fx post..?
Statistics: Posted by nay-seven — 10 Jun 2011, 12:18
2011-06-10T10:26:47+01:00 2011-06-10T10:26:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19576#p19576 <![CDATA[OSC between two PC's]]> LiveOSC_23fx_v5 Just place that in your: ableton program folder under /Resources/Midi Script/
Start Ableton then load it in under your midi section by pressing: Ctrl+,
I am pretty sure if you simply stick a clip in an play it you should start seeing OSC information like position and volume. Correct me if I'm wrong as I am am at work and can't run a simple test.
Thanks Nay.
Statistics: Posted by CreationFused — 10 Jun 2011, 11:26
2011-06-10T08:11:05+01:00 2011-06-10T08:11:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19575#p19575 <![CDATA[OSC between two PC's]]> I've a 30 days demo version of live 8.2.2 ( same you use..? )+max4live
gone to test today
( btw if you can create a simple example file, i can save time)
Statistics: Posted by nay-seven — 10 Jun 2011, 09:11
2011-06-09T23:39:12+01:00 2011-06-09T23:39:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19572#p19572 <![CDATA[OSC between two PC's]]>
Those 7 messages are coming from usine not ableton. It's very strange!
Statistics: Posted by CreationFused — 10 Jun 2011, 00:39
2011-06-09T23:08:53+01:00 2011-06-09T23:08:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19571#p19571 <![CDATA[OSC between two PC's]]> Statistics: Posted by nay-seven — 10 Jun 2011, 00:08
2011-06-09T22:49:31+01:00 2011-06-09T22:49:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19570#p19570 <![CDATA[OSC between two PC's]]>
/live/device/ ff
Statistics: Posted by CreationFused — 09 Jun 2011, 23:49
2011-06-09T22:38:19+01:00 2011-06-09T22:38:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19569#p19569 <![CDATA[OSC between two PC's]]>
I only get 7 messages when I start usine on the other pc
Statistics: Posted by nay-seven — 09 Jun 2011, 23:38
2011-06-09T22:24:38+01:00 2011-06-09T22:24:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19568#p19568 <![CDATA[OSC between two PC's]]>
What message are you talking about?
Statistics: Posted by CreationFused — 09 Jun 2011, 23:24
2011-06-09T21:54:48+01:00 2011-06-09T21:54:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19567#p19567 <![CDATA[OSC between two PC's]]> try also to completely disable firewall on the 2 machine to be sure..?
Statistics: Posted by nay-seven — 09 Jun 2011, 22:54
2011-06-09T21:33:50+01:00 2011-06-09T21:33:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=2905&p=19566#p19566 <![CDATA[OSC between two PC's]]>
I've been busy working away, slowly sorting my osc usine to ableton setup and I have it running perfectly within a single pc environment.
However, I have finally sorted myself a multitouch windows tablet and have been trying to sort getting communication between my ableton laptop and my usine tablet. I can't get any of the osc information from ableton, I only get 7 messages when I start usine on the other pc.
I have check the firewall and opened everything in windows 7 between ableton and the tablet. Still nothing.
Any ideas on where I am going wrong?
Statistics: Posted by CreationFused — 09 Jun 2011, 22:33
so i've now:
works for me...
Thanks Nay.
gone to test today
/live/device/ ff
