ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-06-02T21:51:47+01:00https://brainmodular.org/forums/app.php/feed/topic/28932011-06-02T21:51:47+01:002011-06-02T21:51:47+01:00https://brainmodular.org/forums/viewtopic.php?t=2893&p=19504#p19504if needed , there's a tips in the wiki: check here
Statistics: Posted by nay-seven — 02 Jun 2011, 22:51
]]>2011-06-02T21:42:26+01:002011-06-02T21:42:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2893&p=19503#p19503Statistics: Posted by CleverConQueso — 02 Jun 2011, 22:42
2011-06-02T21:33:57+01:002011-06-02T21:33:57+01:00https://brainmodular.org/forums/viewtopic.php?t=2893&p=19502#p19502some useful tool here ! ( just test with string studio , perfect ) thanks a lot to share
one thing : you have to use the link icon to add your link in your post , cause actually they don't work ( I've download directly from the uploader page)
Statistics: Posted by nay-seven — 02 Jun 2011, 22:33
]]>2011-06-02T21:01:11+01:002011-06-02T21:01:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2893&p=19501#p19501 - HERE -
The corners of the XY pad correspond to the relative level of that numbered output.
Statistics: Posted by CleverConQueso — 02 Jun 2011, 22:01
]]>2011-06-02T20:45:12+01:002011-06-02T20:45:12+01:00https://brainmodular.org/forums/viewtopic.php?t=2893&p=19499#p19499 - HERE -
I use it all of the time so I figured I'd share. I splits my 50 key controller into 3 sections and lets you adjust the octave for each keyboard section so that you can play low notes with either hand. The left and right ends have a note-hold so you can free a hand up for waving at your fans. The center includes the Usine Harmony II patch, again, for the lazy keyboardist.
Original version used the XY for a mixer but mixing MIDI code2 for volume seems like it would be problematic. I'll upload the XY volume controller in another post and update this one.
- CCQ -
Statistics: Posted by CleverConQueso — 02 Jun 2011, 21:45
]]>BrainModularBrainModular Users Forum2011-06-02T21:51:47+01:00https://brainmodular.org/forums/app.php/feed/topic/28932011-06-02T21:51:47+01:002011-06-02T21:51:47+01:00https://brainmodular.org/forums/viewtopic.php?t=2893&p=19504#p19504if needed , there's a tips in the wiki: check here
]]>2011-06-02T21:33:57+01:002011-06-02T21:33:57+01:00https://brainmodular.org/forums/viewtopic.php?t=2893&p=19502#p19502some useful tool here ! ( just test with string studio , perfect ) thanks a lot to share
- CCQ -
