ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-05-09T00:39:41+02:00https://brainmodular.org/forums/app.php/feed/topic/28602011-05-09T00:39:41+02:002011-05-09T00:39:41+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19298#p19298a text in french yesterday but it was late and i haven't enough time to write it in english Even if it is not an important patch as i respect every one on the forum i consider that it must be understandable for all i now have the time to put it right In fact i attempt to simulate the advance of a singing procession who comes from far and pass in front of you and after goes on when the procession begins the sound comes from the left speaker very loud and as the crowd approach the sound increases slowly and when the singing procession is in front of you the sound is at the maximum the two speakers work and when the procession goes on her walking the sound decreases slowly and and ends on the right speaker i hope it's understandable in fact it's made with an old subpatch which was in the 4.22 version to pan and i just adapt it for the gain that' s all Kind Regards
Statistics: Posted by waolelaid — 09 May 2011, 00:39
]]>2011-05-08T06:43:51+02:002011-05-08T06:43:51+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19295#p19295 i'm sorry if i begin by the end but je m'emmele les crayons hello joffo , don't be afraid the switch button lets you chose wether you use the curve point or not when the switch is on you rule the gain with the curve point and when it is off the gain is at zero i yet use the 5.25j so may be it doesn't work with the last release i'd want to know if it's the same to upload the patch i modified in fact it's an old subpatch i kept used for pan tant pis je continue en français trop long à expliquer en anglais en fait je cherchais à simuler une procession qui part d'un endroit et qui passe devant toi donc le son commence d'un coté avec un gain réglé assez bas qui augmente au fur et à mesure que la procession avance quand la procession est devant toi elle est normalement au point culminant du son et quand elle commence à changer de coté le son redescend au fur et à mesure ça fonctionne les deux "point curve" etant réglée avec trois points chacune celle du paner de -100 à 100 et le gain de -8 à mettons 6 quand le paner passe par le point 0 le son est au point le plus haut et redescend vers -8 au fur et à mesure que le paner change de coté jusqu'au moment ou la foule etant passée on ne l'entend plus mais si on me dit comment on fait pour uploader le patch je le mets ou alors je l'envoie à nay qui le mettra toutes mes excuses pour avoir enfrein les règles mais c'est une habitude chez moi depuis tout petit en fait ça marche meme sans le paner et tu rajoutes les points que tu veux oups it's almost the hour to go to bed so good night and for you good morning
Statistics: Posted by waolelaid — 08 May 2011, 06:43
]]>2011-05-07T22:22:45+02:002011-05-07T22:22:45+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19294#p19294Statistics: Posted by joffo78 — 07 May 2011, 22:22
2011-05-07T21:05:18+02:002011-05-07T21:05:18+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19293#p19293Statistics: Posted by nay-seven — 07 May 2011, 21:05
]]>2011-05-07T20:18:59+02:002011-05-07T20:18:59+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19292#p19292Statistics: Posted by joffo78 — 07 May 2011, 20:18
]]>2011-05-07T19:56:39+02:002011-05-07T19:56:39+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19291#p19291 good evening
Statistics: Posted by waolelaid — 07 May 2011, 19:56
]]>2011-05-06T12:57:28+02:002011-05-06T12:57:28+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19271#p19271I d'ont find the module which permit me to control an audio volume with curve with point. Thank
Statistics: Posted by joffo78 — 06 May 2011, 12:57
]]>BrainModularBrainModular Users Forum2011-05-09T00:39:41+02:00https://brainmodular.org/forums/app.php/feed/topic/28602011-05-09T00:39:41+02:002011-05-09T00:39:41+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19298#p19298a text in french yesterday but it was late and i haven't enough time to write it in english Even if it is not an important patch as i respect every one on the forum i consider that it must be understandable for all i now have the time to put it right In fact i attempt to simulate the advance of a singing procession who comes from far and pass in front of you and after goes on when the procession begins the sound comes from the left speaker very loud and as the crowd approach the sound increases slowly and when the singing procession is in front of you the sound is at the maximum the two speakers work and when the procession goes on her walking the sound decreases slowly and and ends on the right speaker i hope it's understandable in fact it's made with an old subpatch which was in the 4.22 version to pan and i just adapt it for the gain that' s all Kind Regards
]]>2011-05-07T21:05:18+02:002011-05-07T21:05:18+02:00https://brainmodular.org/forums/viewtopic.php?t=2860&p=19293#p19293Statistics: Posted by nay-seven — 07 May 2011, 21:05
