ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-05-05T16:31:09+01:00 https://brainmodular.org/forums/app.php/feed/topic/2855 2011-05-05T16:31:09+01:00 2011-05-05T16:31:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=2855&p=19262#p19262 <![CDATA[xy pad in symetric mode doesn't transmit the value of the 2d ball]]> Statistics: Posted by nay-seven — 05 May 2011, 17:31
2011-05-05T15:42:39+01:00 2011-05-05T15:42:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=2855&p=19261#p19261 <![CDATA[xy pad in symetric mode doesn't transmit the value of the 2d ball]]> first to have the good movement i had to conserve 1-x and invers axis on the draw trajectory and even my xy pad !
thank you to had a look i had this multiple variable to choose between symetric x or symetric xy :
Statistics: Posted by joffo78 — 05 May 2011, 16:42
2011-05-05T15:12:14+01:00 2011-05-05T15:12:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=2855&p=19257#p19257 <![CDATA[xy pad in symetric mode doesn't transmit the value of the 2d ball]]> mouse down information and with your use you don't have this, don't know if it's a bug or not
waiting for this here a workaround :
you can also notice i've delete the first 1-x between the draw trajectory and the XY module, for this just edit the layout of the draw trajectory and choose inverse y axis
Statistics: Posted by nay-seven — 05 May 2011, 16:12
2011-05-05T14:45:51+01:00 2011-05-05T14:45:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=2855&p=19256#p19256 <![CDATA[xy pad in symetric mode doesn't transmit the value of the 2d ball]]> example midi surround panner
try to draw a trajectory and see the output of x2 y2
Statistics: Posted by joffo78 — 05 May 2011, 15:45
2011-05-05T14:09:04+01:00 2011-05-05T14:09:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=2855&p=19252#p19252 <![CDATA[xy pad in symetric mode doesn't transmit the value of the 2d ball]]> all seems ok here.
edit : but i suppose you mean you use the inlet of this module to change the values, so the mouse down is always off..?
Statistics: Posted by nay-seven — 05 May 2011, 15:09
2011-05-05T13:25:18+01:00 2011-05-05T13:25:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2855&p=19250#p19250 <![CDATA[xy pad in symetric mode doesn't transmit the value of the 2d ball]]> I noticed when i try to modify the value of the x1 or y1 of a xy pad in symetric mode i can see the second ball moving but the output value isn't modified. Isn't it a paradox ?
Statistics: Posted by joffo78 — 05 May 2011, 14:25
