ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-04-21T17:47:33+01:00 https://brainmodular.org/forums/app.php/feed/topic/2840 2011-04-21T17:47:33+01:00 2011-04-21T17:47:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=2840&p=19118#p19118 <![CDATA[SysEx editor for old hardware synths]]>
In my attempt, I set the fader value range 0-99. Was surprised that I couldn't see that in the Array properties window.
Thanks again.
Statistics: Posted by e.g.: — 21 Apr 2011, 18:47
2011-04-21T13:45:10+01:00 2011-04-21T13:45:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=2840&p=19117#p19117 <![CDATA[SysEx editor for old hardware synths]]> Image
and if you activate the midi out trace function in the globalsetup/midi out you'll see something like this :
[267] SysEx Sent [length=7]
[268] OUT:Begin Sysex (0):
[269] OUT:67
[270] OUT:16
[271] OUT:1
[272] OUT:14
[273] OUT:4
[274] OUT:0005CC44:247-End SysEx
you don't see the value 5 move because the max of the array is 247 , so a change 0_5 is not enough significant to be visible...
Statistics: Posted by nay-seven — 21 Apr 2011, 14:45
2011-04-21T13:27:15+01:00 2011-04-21T13:27:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=2840&p=19116#p19116 <![CDATA[SysEx editor for old hardware synths]]>
If the fader is connected to the Array, shouldn't I be able to see the Array value change as I move the fader?
Shouldn't the SysEx module and modifiers be connected to the corresponding out of the Array (in your example val5)?
I imagine that I need a MIDI in/out module(s) to select channels?
Statistics: Posted by e.g.: — 21 Apr 2011, 14:27
2011-04-21T12:34:24+01:00 2011-04-21T12:34:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=2840&p=19115#p19115 <![CDATA[SysEx editor for old hardware synths]]> Statistics: Posted by e.g.: — 21 Apr 2011, 13:34
2011-04-21T07:25:36+01:00 2011-04-21T07:25:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=2840&p=19096#p19096 <![CDATA[SysEx editor for old hardware synths]]> here a simple example with an array ( min =0, max = 247 ) and a sysex editor module ( modules/midi) :
Statistics: Posted by nay-seven — 21 Apr 2011, 08:25
2011-04-21T03:59:02+01:00 2011-04-21T03:59:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=2840&p=19095#p19095 <![CDATA[SysEx editor for old hardware synths]]>
I have the SysEx messages for all the synth parameters. Unfortunately, I am a complete and confused newb with Usine. I would appreciate some help.
Thanks.
Statistics: Posted by e.g.: — 21 Apr 2011, 04:59
Thanks again.
[269] OUT:67
[270] OUT:16
[271] OUT:1
[272] OUT:14
[273] OUT:4
Thanks.
