ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-04-23T09:26:02+01:00 https://brainmodular.org/forums/app.php/feed/topic/2832 2011-04-23T09:26:02+01:00 2011-04-23T09:26:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=2832&p=19131#p19131 <![CDATA[Rec_Anything]]>
This week i am working a lot and i am not at home. So i didn't have time to read and answer to you.
I need to play the automation in loop mode and without sync beetwen the different fader and knob etc ...
You are right each datas should have his independent start and end. No sync beetwen them.
I will be at home sunday evening and i try to be more clear in the next reply.
Thank you, very much.
Statistics: Posted by cmodica — 23 Apr 2011, 10:26
2011-04-16T20:19:23+01:00 2011-04-16T20:19:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=2832&p=19031#p19031 <![CDATA[Rec_Anything]]> converted all my big patch to just two scripts, a matrix and a line module. im happy
so in not synced mode, the first rec define length and autoloop playback on end, then new recs will overdub same length.
it can rec new differents items without erasing other datas, so all datas get their own independant start and end.
it seem to work even if rec several items so that's cool. hoever they are then in loop mode, looping forever, so unsyncing
together.. not sure it is really cool and wanted behaviour? mm maybe i should find a way to make an array of triggers or single trigger to trig them all to play once, not in loop,
what did you want exactly by not synced cmodia?,do you want them to be in loop or played via button.
i understand for the first rec. ie a fader rec and loop at end, but then
for the next datas that will be rec, ie a second fader, should it have also it's independant start and end or should they
match first rec length/sync? don't know if see what i mean...
Statistics: Posted by 23fx23 — 16 Apr 2011, 21:19
2011-04-15T17:41:25+01:00 2011-04-15T17:41:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=2832&p=19029#p19029 <![CDATA[Rec_Anything]]>
i know im a bit long and late, but im working on it nearly every nights now to improve and post as an addon asap.
got too much 'real work' (working on justice next clip).
the actual version is nearly finished, and i start to be happy of the actual build. I reduced all the complex options to a very simple to use single matrix menu. with cool features to process the curves (powerful AON random generator of thomas, and multiples editing modes likeXY scale/shift, roll, swapXY,blur,sharpen, Sin, saw,tri, square generators. every autom can get it's independant lenght, speed, loop factor, precision and layout type.
so far so good every thing seems to work like a charm..
..but i didn't found yet a way to make it 'not synchro' easily, as all the patch was centered about a circular synced buffer idea.
i will work on that idea tonight..
so what do you ideally need, that a record can be trigged anytime, then loop when ended, with possibility as well to overdub,
that's it? if so, would a 32 bars limit be ok for you (even if you will rec ie 5,2 bars.
Wonder how to deal the lenght, the first rec will define the length i suppose, with an 'erase rec'.
back to work :)
Statistics: Posted by 23fx23 — 15 Apr 2011, 18:41
2011-04-15T17:30:41+01:00 2011-04-15T17:30:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=2832&p=19028#p19028 <![CDATA[Rec_Anything]]> you can find it in this topic :
http://www.sensomusic.com/forums/viewtopic.php?id=2736
and 23fx23 ( certainly over busy ) will be the man for your questions:)
Statistics: Posted by nay-seven — 15 Apr 2011, 18:30
2011-04-15T14:39:01+01:00 2011-04-15T14:39:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=2832&p=19027#p19027 <![CDATA[Rec_Anything]]> I just have been trying it and work very well. But i search a way to record automation without synchro (i can do it with the patch REC_ANYTHING_A.pat) but with the possybility to rec in overdub.
For exemple i record a fader mouvement and later in the live i want to record a knob mouvement without clear the fader mouvement. I can do it with 2 REC_ANYTHING patches but i had to program 2 REC button on my midi controller ..
Is there a way to do that ?
I can do it too with the 2 patches in the ''essai datacorder.wkp'' but same problem i need 2 REC button (and i had to adapt these 2 patches to replace XY module with a rec button, but i can do it.)
I hope i am clear ...
Thanks.
Statistics: Posted by cmodica — 15 Apr 2011, 15:39
back to work :)
Thanks.
