PS:In the next version all midi transform will work for polyphonic messages.
Yeah! Good news, as usual.. Thanks.
Statistics: Posted by Guest — 04 Mar 2007, 20:22
]]>2007-03-04T20:11:58+01:002007-03-04T20:11:58+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1365#p1365Statistics: Posted by senso — 04 Mar 2007, 20:11
2007-03-04T16:01:06+01:002007-03-04T16:01:06+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1361#p1361But I'm not that kind of hunter. I maybe should have say "trapper".
Statistics: Posted by Guest — 04 Mar 2007, 16:01
]]>2007-03-03T18:45:45+01:002007-03-03T18:45:45+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1357#p1357Statistics: Posted by senso — 03 Mar 2007, 18:45
]]>2007-03-03T16:40:22+01:002007-03-03T16:40:22+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1355#p1355Statistics: Posted by Guest — 03 Mar 2007, 16:40
]]>2007-03-03T11:07:59+01:002007-03-03T11:07:59+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1353#p1353
]]>2007-03-03T04:15:12+01:002007-03-03T04:15:12+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1348#p1348I'm just wondering why such a simple thing is so complicated. In SynthEdit there is an existing module called Midi Filter. Well, OK. I just take it, two Lists to put limits on the note filter, two I/O, and make a DLL (≈0% CPU). And use it in Usine. It's just perfect. I can sleep now. Please don't wake me up too early today with your crazy synths!
Statistics: Posted by Guest — 03 Mar 2007, 04:15
]]>2007-03-01T02:32:35+01:002007-03-01T02:32:35+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1310#p1310 A new topic specially for that stupid patch!
I forgot to explain a very important purpose of that patch: it's done to be used in correlation with a keyboard splitter. And when you split, you have shorter keyboards... well, not with the mapper! Example with two splits (but you can have 3 splits with the Range Fader Module): - Split 1: from 0 to 63, Octave = 1 - Split 2: from 64 to 127, remap all black keys of the 2 first octaves (64 to 88 = 10 keys) to 53...62. As you see, that can easily expand and overlap splits for interesting instrumentation. Not really shorter keyboards, but much more complicated... Well, as you said, Olivier, ?Everything has a cost...?
Waiting I'll manage to implement the note range filter in the script (it does not work with modules, no polyphony), this MIDI Mote Mapper Patch needs a small free Midi plug-in. It's all in this tiny ZIP (7 days until now).
Don't tell me you don't need such a stuff, I'll believe you.
]]>2007-03-04T16:01:06+01:002007-03-04T16:01:06+01:00https://brainmodular.org/forums/viewtopic.php?t=278&p=1361#p1361But I'm not that kind of hunter. I maybe should have say "trapper".
