ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-03-15T19:44:53+01:00 https://brainmodular.org/forums/app.php/feed/topic/2778 2011-03-15T19:44:53+01:00 2011-03-15T19:44:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=2778&p=18669#p18669 <![CDATA[error message when i work with osc]]> Statistics: Posted by joffo78 — 15 Mar 2011, 19:44
2011-03-15T12:15:47+01:00 2011-03-15T12:15:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=2778&p=18656#p18656 <![CDATA[error message when i work with osc]]>
My problem of osc is solved
just to know, and to help other.
what was the problem and how you solved it ?
PS : for your questions about the matrix, i transfered them in the appropriate thread, here
Statistics: Posted by martignasse — 15 Mar 2011, 12:15
2011-03-13T21:39:23+01:00 2011-03-13T21:39:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=2778&p=18631#p18631 <![CDATA[error message when i work with osc]]>
i hope i will can manipulate values in the matrix as i asked you.
thank you
Statistics: Posted by joffo78 — 13 Mar 2011, 21:39
2011-03-13T17:28:45+01:00 2011-03-13T17:28:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=2778&p=18630#p18630 <![CDATA[error message when i work with osc]]> it's a good thing to meet you because i had a lot of suggestions for your amazing matrix module !
it would be fantastic if we could take an individual value on each cell by numeric value (for example cell n°25 at 0.5)
it would be great to if you could display each number of cell then a value corresponding of the cell content (cell 1/0.78 cell 2/1 cell 3/0.52 etc).
i'd like to change the value of only one of the cell without changing the other (at the array input make a script for selecting cell then value).
i hope we could understand me.
and for the osc i can't manage to resolve my trouble.
thanks
JF
Statistics: Posted by joffo78 — 13 Mar 2011, 17:28
2011-03-13T16:58:53+01:00 2011-03-13T16:58:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=2778&p=18629#p18629 <![CDATA[error message when i work with osc]]>
usine display "error:Send failed: socket permission denied"
seems like the firewall is blocking the socket creation.
check if the port used by usine for OSC is in the exception list of the firewall, create it if needed
hop it help
Statistics: Posted by martignasse — 13 Mar 2011, 16:58
2011-03-13T16:16:10+01:00 2011-03-13T16:16:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=2778&p=18628#p18628 <![CDATA[error message when i work with osc]]> i meet some trouble when i try to work with osc (only with one of my 2 computers).
and i can't send osc informations in another software. Usine and the other are correctly configurated because when i do the same on another computer it works...
Statistics: Posted by joffo78 — 13 Mar 2011, 16:16
thank you
thanks
JF
hop it help
