ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-03-03T16:48:27+01:00 https://brainmodular.org/forums/app.php/feed/topic/276 2007-03-03T16:48:27+01:00 2007-03-03T16:48:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=276&p=1356#p1356 <![CDATA[Ctrl+Suppr !!!]]> I'm not sure that scripts are often used... But they can be very useful anyway. Don't work too much on that, it's not a priority.
Statistics: Posted by Guest — 03 Mar 2007, 16:48
2007-03-02T08:46:22+01:00 2007-03-02T08:46:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=276&p=1328#p1328 <![CDATA[Ctrl+Suppr !!!]]> Remote keys by myself.
It's why there is a difference.
already done
ctrl+s in script = save script
I'll take look.
Statistics: Posted by senso — 02 Mar 2007, 08:46
2007-03-01T23:30:46+01:00 2007-03-01T23:30:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=276&p=1323#p1323 <![CDATA[Ctrl+Suppr !!!]]> As the script editor closes itself when clicking anywhere in the workspace (eg. impossible to edit both at the same time), I thought that it could have it's special shortcuts (and de-active the usual ones)...
Maybe a lot of work.
Statistics: Posted by Guest — 01 Mar 2007, 23:30
2007-02-27T19:32:35+01:00 2007-02-27T19:32:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=276&p=1292#p1292 <![CDATA[Ctrl+Suppr !!!]]> I'll check the ctrl+S and Ctrl+C in the script
Statistics: Posted by senso — 27 Feb 2007, 19:32
2007-02-27T17:31:00+01:00 2007-02-27T17:31:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=276&p=1291#p1291 <![CDATA[Ctrl+Suppr !!!]]> But please, not is the script editor!
As well as Ctrl+S, that maybe could save the script and not the workspace.
And this is not important: Ctrl+C does not work in "help-page". But I'm supposed to get rid one day of that page, right?
Statistics: Posted by Guest — 27 Feb 2007, 17:31
2007-02-27T09:09:49+01:00 2007-02-27T09:09:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=276&p=1284#p1284 <![CDATA[Ctrl+Suppr !!!]]> Which one do you suggest for "clear current patch".
Statistics: Posted by senso — 27 Feb 2007, 09:09
2007-02-27T01:01:46+01:00 2007-02-27T01:01:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=276&p=1277#p1277 <![CDATA[Ctrl+Suppr !!!]]>
In most text editors (all of them?) Ctrl+Del deletes the next word after the cursor. Just try it while you're answering posts.
What happens in Usine when you are editing a script in a saved workspace and you Ctrl+Del(ete) a word in your *not-yet-saved* script ?
Well, I had a very bad surprise...! Big eyes!
I'm not sure you should leave such a shortcut for such an irreversible action.
Not a bug, right?
Thanks, thanks (singing and exiting)...
Statistics: Posted by Guest — 27 Feb 2007, 01:01
already done
I'll take look.
Not a bug, right?
