ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2013-02-08T22:13:52+01:00https://brainmodular.org/forums/app.php/feed/topic/27382013-02-08T22:13:52+01:002013-02-08T22:13:52+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=25364#p25364 this works also! the first division is by 12 and the multiplications are also *12
Statistics: Posted by AndrewChi — 08 Feb 2013, 22:13
not sure if its the most efficient way to do this but it works.
Statistics: Posted by soundmind — 02 Mar 2011, 20:20
]]>2011-03-02T20:13:49+01:002011-03-02T20:13:49+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=18328#p18328 a less elegant solution would be:
Statistics: Posted by ethnix73 — 02 Mar 2011, 20:13
]]>2011-03-02T20:00:18+01:002011-03-02T20:00:18+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=18325#p18325 if i well understood, another method is to make a 12 size array, then the incoming note moded by 12 output is used as index for a getArrayEmt module, to get the correct value for all octaves from this single 'scale' octave array. then to recompose the modified note, pick the out of getArrayElmt and add this to the actual octave: (note div 12)*12
]]>2011-03-02T19:45:54+01:002011-03-02T19:45:54+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=18324#p18324Statistics: Posted by soundmind — 02 Mar 2011, 19:45
2011-03-02T18:50:13+01:002011-03-02T18:50:13+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=18320#p18320Statistics: Posted by moody33 — 02 Mar 2011, 18:50
]]>2011-03-02T18:30:16+01:002011-03-02T18:30:16+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=18319#p18319Statistics: Posted by soundmind — 02 Mar 2011, 18:30
]]>BrainModularBrainModular Users Forum2013-02-08T22:13:52+01:00https://brainmodular.org/forums/app.php/feed/topic/27382013-02-08T22:13:52+01:002013-02-08T22:13:52+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=25364#p25364 this works also! the first division is by 12 and the multiplications are also *12
]]>2011-03-02T18:50:13+01:002011-03-02T18:50:13+01:00https://brainmodular.org/forums/viewtopic.php?t=2738&p=18320#p18320Statistics: Posted by moody33 — 02 Mar 2011, 18:50
