maybe the "ignore time clock" in the setup is activated?
No, it is not.
Ok, I'm a little rusty right now but if I am correct I should be able to load the Receive MIDI Clock sub patch into a patch and connect the midi out from the midi input module to all of the midi inputs to the patch and fully control Usine via remote transport and remote tempo, correct? All I am getting is remote transport.. and this is definately not a problem of my external gear not sending clock. Everything else is working fine from the same clock, but I can't help but think I am doing something wrong if no one else has this problem..?
Statistics: Posted by gurulogic — 29 Jun 2011, 10:05
]]>2011-06-29T07:38:45+01:002011-06-29T07:38:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2720&p=19818#p19818Statistics: Posted by senso — 29 Jun 2011, 08:38
]]>2011-06-28T18:42:31+01:002011-06-28T18:42:31+01:00https://brainmodular.org/forums/viewtopic.php?t=2720&p=19807#p19807Statistics: Posted by gurulogic — 28 Jun 2011, 19:42
]]>2011-02-25T07:15:26+01:002011-02-25T07:15:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2720&p=18168#p18168Statistics: Posted by gurulogic — 25 Feb 2011, 07:15
]]>2011-02-25T05:56:00+01:002011-02-25T05:56:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2720&p=18167#p18167Statistics: Posted by Floego — 25 Feb 2011, 05:56
]]>2011-02-25T05:03:51+01:002011-02-25T05:03:51+01:00https://brainmodular.org/forums/viewtopic.php?t=2720&p=18165#p18165I have connected all 5 midi "in" to my midi input and turned the patch on but no go. If I use the older version of the receive midi clock patch it works. Am I missing something?
Statistics: Posted by gurulogic — 25 Feb 2011, 05:03
]]>BrainModularBrainModular Users Forum2011-06-29T18:25:49+01:00https://brainmodular.org/forums/app.php/feed/topic/27202011-06-29T18:25:49+01:002011-06-29T18:25:49+01:00https://brainmodular.org/forums/viewtopic.php?t=2720&p=19820#p19820Statistics: Posted by gurulogic — 29 Jun 2011, 19:25
]]>2011-06-29T09:05:50+01:002011-06-29T09:05:50+01:00https://brainmodular.org/forums/viewtopic.php?t=2720&p=19819#p19819
No, it is not.
