ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-03-25T12:20:17+02:00https://brainmodular.org/forums/app.php/feed/topic/27022011-03-25T12:20:17+02:002011-03-25T12:20:17+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18815#p18815Statistics: Posted by 23fx23 — 25 Mar 2011, 11:20
2011-03-25T11:45:16+02:002011-03-25T11:45:16+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18814#p18814 All the coding is pretty much done so I am finally getting to use it to make music and it is great fun to have this level of control over Csound in realtime.
]]>2011-03-25T11:09:45+02:002011-03-25T11:09:45+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18812#p18812 The new features sounds really useful.
take your time!:)
Statistics: Posted by headphoner — 25 Mar 2011, 10:09
]]>2011-03-24T21:54:07+02:002011-03-24T21:54:07+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18806#p18806 It took a little longer than originally anticipated as I added in a few new features that my original prototype lacked e.g it can now also output midi so can be used for purely midi effects. Also it can now output k-rate variables through its parameters too so you can use Csound to automate Usine e.g as an LFO or create random numbers, envelopes etc.
Just need to finish the documentation off - I have started adding a page to the wiki documenting the module so you can read that in preparation now and I am working on an article for the Csound Journal that will also provide a good tutorial to using Csound in Usine. I am also adding examples too so let me know if there is examples you want to see or any aspects of Csound you would like explaining or tutorials for.
]]>2011-03-24T20:47:10+02:002011-03-24T20:47:10+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18805#p18805 i'm testing csound everyday and i'm wainting your module
arrrgghhh!
Statistics: Posted by headphoner — 24 Mar 2011, 19:47
As of today I have completed all the features I wanted to add, now it is just a case of writing documentation, examples, wiki etc and finalizing the last few tweaks to the code. Not too long to wait now...
]]>2011-03-10T20:24:22+02:002011-03-10T20:24:22+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18573#p18573 can we'll see this beautiful module soon ?
Statistics: Posted by headphoner — 10 Mar 2011, 19:24
]]>2011-03-01T02:54:12+02:002011-03-01T02:54:12+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18268#p18268 This is pretty huge! Thanks for doing this!!
Statistics: Posted by Clearscreen — 01 Mar 2011, 01:54
]]>2011-02-28T22:32:22+02:002011-02-28T22:32:22+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18250#p18250Statistics: Posted by moody33 — 28 Feb 2011, 21:32
]]>2011-02-28T20:55:05+02:002011-02-28T20:55:05+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18241#p18241thx cacao!
]]>2011-02-23T13:52:50+02:002011-02-23T13:52:50+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18146#p18146great!!!!!!!! this brings Usine+Csound in the line of Ableton+Max4Live. unbelievable ...it´s a dream that comes true great caco! really great!
]]>2011-02-23T13:30:19+02:002011-02-23T13:30:19+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18144#p18144Statistics: Posted by caco — 23 Feb 2011, 12:30
]]>2011-02-23T00:33:18+02:002011-02-23T00:33:18+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18138#p18138 So many more possibilities caco!
Thanks in advance
Statistics: Posted by ethnix73 — 22 Feb 2011, 23:33
]]>2011-02-22T21:37:17+02:002011-02-22T21:37:17+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18137#p18137Statistics: Posted by soundmind — 22 Feb 2011, 20:37
]]>2011-02-22T18:32:04+02:002011-02-22T18:32:04+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18136#p18136It seems that I'm never gonne be able to leave Usine aside for more than two days, and you don't help !! thanks²
Statistics: Posted by tanabarbier — 22 Feb 2011, 17:32
]]>2011-02-22T17:26:12+02:002011-02-22T17:26:12+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18135#p18135Statistics: Posted by headphoner — 22 Feb 2011, 16:26
]]>2011-02-22T17:25:04+02:002011-02-22T17:25:04+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18134#p18134Statistics: Posted by nay-seven — 22 Feb 2011, 16:25
]]>2011-02-22T17:14:57+02:002011-02-22T17:14:57+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18133#p18133 If you want to write your own csound scripts then qutecsound or winXound are helpful but not essential. Csound's .csd files are just text files so you can use wordpad if you want.
I will upload the first beta version next week. So far it seems to be working fine for me and I am now just writing some basic examples to explain the user module but really it is very simple, it works just like any other usine module
]]>2011-02-22T16:50:00+02:002011-02-22T16:50:00+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18131#p18131but this means we must have qutecsound or equivalent running in the back or it's totally independent..? impatient too..
Statistics: Posted by nay-seven — 22 Feb 2011, 15:50
]]>2011-02-22T16:40:05+02:002011-02-22T16:40:05+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18130#p18130It's probably the greatest improvement of Usine since usine V1.0 itself ! It will add many, many, many features in Usine. Thanks for this module, I'm impatient to test it. senso+++
It has csound embedded in it and can open csound's .csd files.
Csound is probably the most powerful software synth/effect in existence. With csound running in usine you can create pretty much anything you can imagine!
It can be used to create effects and process audio in realtime. It also has realtime midi input support so it can be used to create and play synths etc. There are 4 generic params exposed to usine that are connected to csound's internal buses so you can automate csound directly from usine with LFOs etc. And if 4 buses plus midi isn't enough control you can communicate directly with the embedded csound instance from usine using OSC.
For anybody not familiar with csound it is based on a powerful yet simple scripting language. I will provide some examples with the user module showing how to communicate between csound/usine. For anyone wanting to learn more about csound feel there is an excellent book edited by Dr Richard Boulanger as well as a whole mountain of free tutorials on the internet. Plus I am happy to answer any questions
]]>2011-02-22T13:36:53+02:002011-02-22T13:36:53+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18125#p18125 Is it really csound?
Yeaaaah!
Statistics: Posted by headphoner — 22 Feb 2011, 12:36
]]>BrainModularBrainModular Users Forum2011-03-25T12:20:17+02:00https://brainmodular.org/forums/app.php/feed/topic/27022011-03-25T12:20:17+02:002011-03-25T12:20:17+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18815#p18815Statistics: Posted by 23fx23 — 25 Mar 2011, 11:20
]]>2011-03-25T11:45:16+02:002011-03-25T11:45:16+02:00https://brainmodular.org/forums/viewtopic.php?t=2702&p=18814#p18814 All the coding is pretty much done so I am finally getting to use it to make music and it is great fun to have this level of control over Csound in realtime.
take your time!:)
arrrgghhh!
Thanks in advance
