ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-02-20T21:55:20+02:00https://brainmodular.org/forums/app.php/feed/topic/26932011-02-20T21:55:20+02:002011-02-20T21:55:20+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=18104#p18104 I found the something funny, If the location is "memory", the sound is OK, but if the location is "file" (you need to set file and then load a new sound), there's a lots of clicks...
After a quick test, i don't hear any change here....
Statistics: Posted by ethnix73 — 20 Feb 2011, 16:17
]]>2011-02-20T16:06:00+02:002011-02-20T16:06:00+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=18101#p18101 well, I tried the patch Ethnics73 proposed for a pause solution but the fact is it doesn't work...
Actually, this patch is like connecting Pos out to Start pos In ( with an exception at the end of the file) but that is what I mentioned above, you can't do it because it disturbs the sound.
]]>2011-02-14T17:34:07+02:002011-02-14T17:34:07+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=18018#p18018 For the relative path, maybe use the concatlist script to feed the comma input should do the job, second list being relative paths, first being the root.
]]>2011-02-10T14:58:07+02:002011-02-10T14:58:07+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=17974#p17974 Step by step
1°) Zero Cross : The Zéro cross option is effective for me whatever the position. Generaly I dont use the pos request but directly the pos inlet if i want to move the play position during the playback.
2°) I don't realy understand your question...
3°) relative paths: For the moment no, you cant use the relative path for the files
4°) For the export : All the files loaded in sampler are exported withe the CTRL+E (Export patch fonction)
Best
Statistics: Posted by multiphone — 10 Feb 2011, 13:58
]]>2011-02-10T14:27:28+02:002011-02-10T14:27:28+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=17972#p17972 Thanks for this pause solution.
About the export, my patch is quite complex with many presets... The only exported files are the ones which are loaded.
it's because the play and stop button works only when synchro of the sampler = play button
If you are in this mode, you should disconnect the wire from the outlet start pos of the wav display module linked to the inlet pos of the sampler.
To do a pause function within the play button mode, you could try something like this:
Statistics: Posted by ethnix73 — 10 Feb 2011, 00:41
]]>2011-02-10T00:50:26+02:002011-02-10T00:50:26+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=17967#p17967Statistics: Posted by nay-seven — 09 Feb 2011, 23:50
2011-02-10T00:39:53+02:002011-02-10T00:39:53+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=17966#p17966 Thanks, Nay seven, but the question was rather " why does my solution doesn't work ? " I'd just like to understand.
I tried to export the workspace but it didn't work in my case... Maybe the idea of the relative path would be a good request for a next version...
and you can try the export mode for your patch, but no relative path
Statistics: Posted by nay-seven — 09 Feb 2011, 21:49
]]>2011-02-09T22:08:28+02:002011-02-09T22:08:28+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=17957#p17957"" Secondly : Is it possible to use relative paths for the sound files like " \my patchsoundbass.wav" instead of "d:\my patchsoundsound.wav" in case I want to set my patch in an another folder...
And the last : why wiring the "pos" output to the "start pos" disturbs the sound when it plays ? Isn't "start pos" suppose to be effective only when you start the file ?
I was expecting to transform the "stop" in "pause" like this :
Cheers !
Kenan
PS : The thread "some clicks with the sampler" is updated and I guess there's still some problems despite the new release.
]]>BrainModularBrainModular Users Forum2011-02-20T21:55:20+02:00https://brainmodular.org/forums/app.php/feed/topic/26932011-02-20T21:55:20+02:002011-02-20T21:55:20+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=18104#p18104 I found the something funny, If the location is "memory", the sound is OK, but if the location is "file" (you need to set file and then load a new sound), there's a lots of clicks...
Best
]]>2011-02-10T00:39:53+02:002011-02-10T00:39:53+02:00https://brainmodular.org/forums/viewtopic.php?t=2693&p=17966#p17966 Thanks, Nay seven, but the question was rather " why does my solution doesn't work ? " I'd just like to understand.
Cheers !
Kenan
