ArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-02-10T14:16:31+01:00 https://brainmodular.org/forums/app.php/feed/topic/2690 2011-02-10T14:16:31+01:00 2011-02-10T14:16:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=2690&p=17975#p17975 <![CDATA[Altering Number of Parameters In User Module]]>
Until then, I will just hardcode a fixed set of inputs/outputs into my module and structure my code in a way that can be altered in the future.
Thanks for the reply Senso
Statistics: Posted by caco — 10 Feb 2011, 14:16
2011-02-10T13:39:53+01:00 2011-02-10T13:39:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=2690&p=17973#p17973 <![CDATA[Altering Number of Parameters In User Module]]> I know that I have to implement this feature in Usine with "built-in modules " , and consequently in the SDK with "user's modules".
It will be, I hope , in the next major release.
Statistics: Posted by senso — 10 Feb 2011, 13:39
2011-02-10T13:09:32+01:00 2011-02-10T13:09:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=2690&p=17971#p17971 <![CDATA[Altering Number of Parameters In User Module]]>
Statistics: Posted by caco — 10 Feb 2011, 13:09
2011-02-08T20:02:23+01:00 2011-02-08T20:02:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=2690&p=17951#p17951 <![CDATA[Altering Number of Parameters In User Module]]>
I can use the test query system to be able to set the number of parameters when the module is first created but ideally I would like to be able to add/remove/change parameters during the module's life time. Is this possible? I suspect not from reading through the SDK code but thought I should ask incase I have missed anything :)
Statistics: Posted by caco — 08 Feb 2011, 20:02
