ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-08-21T09:33:30+01:00 https://brainmodular.org/forums/app.php/feed/topic/2689 2012-08-21T09:33:30+01:00 2012-08-21T09:33:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=24087#p24087 <![CDATA[Uslice]]> Unfortunatly, i've not been able to resolve some bugs in this patch, and i could not work more on it because i haven't got anymore a launchpad :(
Anyway, thanks for keeping a copy and sharing it nay-seven!
If you have questions skei, i would be happy to answer you.
Statistics: Posted by ethnix73 — 21 Aug 2012, 10:33
2012-08-20T17:41:59+01:00 2012-08-20T17:41:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=24085#p24085 <![CDATA[Uslice]]> off for experimenting and (hopefully) some learning :-)
Statistics: Posted by skei — 20 Aug 2012, 18:41
2012-08-20T17:32:26+01:00 2012-08-20T17:32:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=24084#p24084 <![CDATA[Uslice]]> yes this patch is not any more on the uploader , i v' keep a copy , you can download it here
I'm also a launchpad user, not easy at first cause first built for ableton, I'll add a video tomorrow with a workspace I'm working on and maybe an add-on later ( I'm using nonome to simplify midi/OSC routing )
Statistics: Posted by nay-seven — 20 Aug 2012, 18:32
2012-08-20T17:13:11+01:00 2012-08-20T17:13:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=24083#p24083 <![CDATA[Uslice]]> clicking the link(s), gives me "Bad request. The link you followed is incorrect or outdated."
is this available anywhere else?
- skei
Statistics: Posted by skei — 20 Aug 2012, 18:13
2011-03-10T23:28:18+01:00 2011-03-10T23:28:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18582#p18582 <![CDATA[Uslice]]>
Statistics: Posted by moody33 — 10 Mar 2011, 23:28
2011-03-10T12:47:24+01:00 2011-03-10T12:47:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18567#p18567 <![CDATA[Uslice]]>
A few improvments:
-Pan parameter
-Start and end position per sampler wich allows to slice only a part of a sample.
-A filter per sampler
-Two different mode for the pitch: Rythm and Melody to make more accurate pitch-shifting.
-A new mode for the recording setting: You can now record audio in and resampling at the same time with the all mode.
A screenshot of the sampler settings panel:
You can download the patch here.
Statistics: Posted by ethnix73 — 10 Mar 2011, 12:47
2011-03-05T16:57:38+01:00 2011-03-05T16:57:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18457#p18457 <![CDATA[Uslice]]>
Statistics: Posted by ethnix73 — 05 Mar 2011, 16:57
2011-03-05T16:54:24+01:00 2011-03-05T16:54:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18456#p18456 <![CDATA[Uslice]]>
Here is a new version. Some little changes to do yet certainly, but the release should be near now.
You will find in the zip file:
- A launchpad version
- A matrix only version
- A Ohm64 version (but with still a few bugs)
- Some documentation ( patch explanation and how to configure another host with Usine vst, here Reaper for the example)
Download it here
Statistics: Posted by ethnix73 — 05 Mar 2011, 16:54
2011-03-05T12:20:34+01:00 2011-03-05T12:20:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18449#p18449 <![CDATA[Uslice]]> Statistics: Posted by soundmind — 05 Mar 2011, 12:20
2011-03-01T11:34:22+01:00 2011-03-01T11:34:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18274#p18274 <![CDATA[Uslice]]>
Don't forget to reset the midi learn on the play buttons.....before making yours....
Statistics: Posted by ethnix73 — 01 Mar 2011, 11:34
2011-03-01T11:29:08+01:00 2011-03-01T11:29:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18273#p18273 <![CDATA[Uslice]]> This one is only for use with a launchpad or a midi controller with the same midi settings as a launchpad.
The main control panel have changed and looks like now:
You can download it here:
[s]http://sensomusic.com/forums/uploads.ph ... d%2011.wkp[/s]
See below
I will upload a version for use without launchpad in the next days...
Statistics: Posted by ethnix73 — 01 Mar 2011, 11:29
2011-02-26T11:05:31+01:00 2011-02-26T11:05:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18197#p18197 <![CDATA[Uslice]]>
i nearly never download from my web site. i will upload it to the forum servers, as i've got a new version....no, two new versions: one for the launchpad, a one only with matrix cells.
By the way, in the version you've downloaded, there is always the bug with drag&drop, it's related with the pm :(...definitivly solved in the two versions i will upload.
Maybe i should start to make the wiki for a better explanation about this patch, but diving in Csound is a temptation difficult to resist :)
Statistics: Posted by ethnix73 — 26 Feb 2011, 11:05
2011-02-26T10:51:17+01:00 2011-02-26T10:51:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18196#p18196 <![CDATA[Uslice]]> Statistics: Posted by soundmind — 26 Feb 2011, 10:51
2011-02-18T12:16:51+01:00 2011-02-18T12:16:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18068#p18068 <![CDATA[Uslice]]>
A few bugs resolved:
-Drag&Drop was not implemented in sampler A and B (:rolleyes:)
-Changing a preset in the PM could could lead to repeat the same cell/pad avoer and over.
-Changing the played file in the option window was not reflected on the matrix/launchpad and inversely
A new function:
-Changing file while pad rec is activated is now recorded
Statistics: Posted by ethnix73 — 18 Feb 2011, 12:16
2011-02-12T18:15:21+01:00 2011-02-12T18:15:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18008#p18008 <![CDATA[Uslice]]> (your gmail..)
Statistics: Posted by ZOUKOUPOMME — 12 Feb 2011, 18:15
2011-02-12T18:07:25+01:00 2011-02-12T18:07:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18007#p18007 <![CDATA[Uslice]]> thanks. Don't hesitate to post your comments (+ or -) when you can test it.
@zoukopomme:
If we manage your ohm64 to work correctly, this patch will be really easily adaptable to it.
Statistics: Posted by ethnix73 — 12 Feb 2011, 18:07
2011-02-12T16:43:30+01:00 2011-02-12T16:43:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18006#p18006 <![CDATA[Uslice]]>
Statistics: Posted by ZOUKOUPOMME — 12 Feb 2011, 16:43
2011-02-12T02:12:30+01:00 2011-02-12T02:12:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=18003#p18003 <![CDATA[Uslice]]> Statistics: Posted by soundmind — 12 Feb 2011, 02:12
2011-02-11T13:34:49+01:00 2011-02-11T13:34:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=17995#p17995 <![CDATA[Uslice]]>
maybe time to upgrade the other one..
Don't know nay-seven :)
It was just to know if it was not too cpu heavy on older configuration...
Statistics: Posted by ethnix73 — 11 Feb 2011, 13:34
2011-02-11T13:33:58+01:00 2011-02-11T13:33:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=17994#p17994 <![CDATA[Uslice]]>
-You can choose file within the matrix now
-Implemented temporary loop within launchpad (press two pad at the same time without releasing them to set the loop, and press only one pad to stop temporary loop), but is not implemented with the matrix cells
-bug fixed= first slice was not played after an audio recording
Statistics: Posted by ethnix73 — 11 Feb 2011, 13:33
2011-02-11T12:45:59+01:00 2011-02-11T12:45:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=17992#p17992 <![CDATA[Uslice]]>
MS Windows 7 64-bit / Intel Pentium T4400 @ 2.20GHz
Statistics: Posted by nay-seven — 11 Feb 2011, 12:45
2011-02-11T11:59:33+01:00 2011-02-11T11:59:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=17991#p17991 <![CDATA[Uslice]]>
slow 80ms
With a core2dou 8400, asio buffer at 128:
Easine with refresh speed at 25ms = 5% to 7%
Usine stand alone with refresh speed at 50ms 5%to 7%
So I will make two final versions....
Statistics: Posted by ethnix73 — 11 Feb 2011, 11:59
2011-02-11T10:43:32+01:00 2011-02-11T10:43:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=17990#p17990 <![CDATA[Uslice]]>
It's quite high. Wich refresh speed setting have you?
slow 80ms
The solution is perhaps to make two diférent versions...
yes, i thinks so !
Statistics: Posted by nay-seven — 11 Feb 2011, 10:43
2011-02-11T10:15:55+01:00 2011-02-11T10:15:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=17989#p17989 <![CDATA[Uslice]]>
i'm around 15/20% on a dual core amd, with asio buffer 128
as i don't have any launchpad, i 'll certainly adapt this to my need ( with special copyright of course
No problem nay-seven. The main dilemna with this patch is too combine function for the launchpad AND the tactile interface.
Statistics: Posted by ethnix73 — 11 Feb 2011, 10:15
2011-02-11T01:13:46+01:00 2011-02-11T01:13:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=2689&p=17987#p17987 <![CDATA[Uslice]]> as i don't have any launchpad, i 'll certainly adapt this to my need ( with special copyright of course :)
Statistics: Posted by nay-seven — 11 Feb 2011, 01:13
- skei
A few improvments:
-Pan parameter
Download it here
See below
A new function:
@zoukopomme:
slow 80ms
slow 80ms
yes, i thinks so !
