ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-02-04T16:28:58+02:00https://brainmodular.org/forums/app.php/feed/topic/26812011-02-04T16:28:58+02:002011-02-04T16:28:58+02:00https://brainmodular.org/forums/viewtopic.php?t=2681&p=17909#p17909Disabled "perfect synchro" and it works!
Statistics: Posted by AndrewChi — 04 Feb 2011, 15:28
]]>2011-02-03T18:48:41+02:002011-02-03T18:48:41+02:00https://brainmodular.org/forums/viewtopic.php?t=2681&p=17906#p17906 1) you've got the option "perfect synchro" in global setup/asio
2)The precision of your fader is not set to integer. Unless your fader is set to integer, the precision will always be float...Other precison modes than integer are only visual feedback..
Statistics: Posted by ethnix73 — 03 Feb 2011, 17:48
]]>2011-02-03T17:46:27+02:002011-02-03T17:46:27+02:00https://brainmodular.org/forums/viewtopic.php?t=2681&p=17905#p17905Statistics: Posted by soundmind — 03 Feb 2011, 16:46
2011-02-03T17:05:54+02:002011-02-03T17:05:54+02:00https://brainmodular.org/forums/viewtopic.php?t=2681&p=17904#p17904which can be easily done with the MasterSync module. I also want the tempo knob on the IB to be updated with tempochanges which are not encoded by this tempo knob (ex. Tap-tempo).
It works when I put a 'pass only if changed' on the MasterSynchro tempo-out and connect it back to the tempo knob, but I get strange tempo's. When I dial 111, Usine's panel will display something like 110,97 or something. I suspect it has something to do with the precision of data flow, or the fact I am making some sort of data-feedback, but I cannot seem to find a decent workaround...
Any ideas?
Thank you!
-----usine rocks
Statistics: Posted by AndrewChi — 03 Feb 2011, 16:05
]]>BrainModularBrainModular Users Forum2011-02-04T16:28:58+02:00https://brainmodular.org/forums/app.php/feed/topic/26812011-02-04T16:28:58+02:002011-02-04T16:28:58+02:00https://brainmodular.org/forums/viewtopic.php?t=2681&p=17909#p17909Disabled "perfect synchro" and it works!
]]>2011-02-03T17:05:54+02:002011-02-03T17:05:54+02:00https://brainmodular.org/forums/viewtopic.php?t=2681&p=17904#p17904which can be easily done with the MasterSync module. I also want the tempo knob on the IB to be updated with tempochanges which are not encoded by this tempo knob (ex. Tap-tempo).
Any ideas?
Thank you!
-----usine rocks
