ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-01-27T22:08:42+02:00https://brainmodular.org/forums/app.php/feed/topic/26742011-01-27T22:08:42+02:002011-01-27T22:08:42+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17830#p17830Ok, as I said in my first post, I wanted to check if it was the simpler option. I'm far from mastering all Usine modules and tricks so I prefer asking before building
Statistics: Posted by La Tenaille — 27 Jan 2011, 21:08
]]>2011-01-27T09:27:26+02:002011-01-27T09:27:26+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17828#p17828Statistics: Posted by bsork — 27 Jan 2011, 08:27
2011-01-27T09:15:09+02:002011-01-27T09:15:09+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17827#p17827Statistics: Posted by woodslanding — 27 Jan 2011, 08:15
]]>2011-01-26T21:50:25+02:002011-01-26T21:50:25+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17826#p17826
connected to separate mixer out modules
mmmm... it still means a MixerOut per track or I miss something ?
Statistics: Posted by La Tenaille — 26 Jan 2011, 20:50
]]>2011-01-26T15:47:54+02:002011-01-26T15:47:54+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17825#p17825 Have as many switches as you have tracks you want to control - these should be stored in the Conductor. Add another "master" switch with MidiLearn - whether this should be stored in the Conductor depends.
Use the track switches together with the master and some logical modules connected to separate mixer out modules. The logic depends on whether you like to see the different switches as mute on or off.
]]>2011-01-26T14:45:20+02:002011-01-26T14:45:20+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17824#p17824Statistics: Posted by cmodica — 26 Jan 2011, 13:45
]]>2011-01-24T21:28:58+02:002011-01-24T21:28:58+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17819#p17819If I understand well your idea, the tracks are mixed together. The trouble is I send separate tracks to the sound engineer. Or I miss something ? Thanks for your advice
Statistics: Posted by La Tenaille — 24 Jan 2011, 20:28
]]>2011-01-24T12:09:43+02:002011-01-24T12:09:43+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17817#p17817 I think the output tracks configuration should be store in a conductor ... i didn't test but you can try.
Statistics: Posted by cmodica — 24 Jan 2011, 11:09
]]>2011-01-22T15:31:45+02:002011-01-22T15:31:45+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17808#p17808 My final goal is to remote the mutes with my pedal board, but i'd like to change the behaviour according to the conductor scenes (mute any track with any pedal switch). So I'm not sure midi learns are a good way. I don't mind using multiple mixer out modules, I was asking to be sure there's not something more suitable. Thanks for your advices !
Statistics: Posted by La Tenaille — 22 Jan 2011, 14:31
]]>2011-01-22T15:07:52+02:002011-01-22T15:07:52+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17807#p17807Statistics: Posted by nay-seven — 22 Jan 2011, 14:07
]]>2011-01-22T14:50:31+02:002011-01-22T14:50:31+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17806#p17806 Perhaps another way would be to link your switch to a "create midi" module (one per track) linked to one "send midi to usine" module, and make midi learn on each mixer track, but i'm not sure it would lighter on cpu...
Statistics: Posted by ethnix73 — 22 Jan 2011, 13:50
]]>2011-01-22T14:32:00+02:002011-01-22T14:32:00+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17805#p17805I'd like to mute 7 tracks with a single switch (and later choose any tracks). I've thought about using a mixer out module, but it means I must add a module per track ? Is it the only option ? Thanks
Statistics: Posted by La Tenaille — 22 Jan 2011, 13:32
]]>BrainModularBrainModular Users Forum2011-01-27T22:08:42+02:00https://brainmodular.org/forums/app.php/feed/topic/26742011-01-27T22:08:42+02:002011-01-27T22:08:42+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17830#p17830Ok, as I said in my first post, I wanted to check if it was the simpler option. I'm far from mastering all Usine modules and tricks so I prefer asking before building
]]>2011-01-27T09:15:09+02:002011-01-27T09:15:09+02:00https://brainmodular.org/forums/viewtopic.php?t=2674&p=17827#p17827Statistics: Posted by woodslanding — 27 Jan 2011, 08:15
