ArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-01-14T23:27:17+01:00https://brainmodular.org/forums/app.php/feed/topic/26642011-01-14T23:27:17+01:002011-01-14T23:27:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17749#p17749Statistics: Posted by héliouk 6 — 14 Jan 2011, 23:27
2011-01-14T09:12:56+01:002011-01-14T09:12:56+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17742#p17742absolutely not tempered ! by default pitch values are rounded but if you connect a fader with a x.xx precision to the pitch inlet, the pitch will be have the same precision. You can have a 12.45 pitch if you want!
]]>2011-01-13T13:43:20+01:002011-01-13T13:43:20+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17735#p17735Statistics: Posted by héliouk 6 — 13 Jan 2011, 13:43
]]>2011-01-13T09:48:56+01:002011-01-13T09:48:56+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17734#p17734grain sampler ( to have better result ) must work..
Statistics: Posted by nay-seven — 13 Jan 2011, 09:48
]]>2011-01-13T09:47:05+01:002011-01-13T09:47:05+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17733#p17733 did you try the smoother module?
Statistics: Posted by headphoner — 13 Jan 2011, 09:47
]]>2011-01-13T09:34:30+01:002011-01-13T09:34:30+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17732#p17732Statistics: Posted by héliouk 6 — 13 Jan 2011, 09:34
]]>BrainModularBrainModular Users Forum2011-01-14T23:27:17+01:00https://brainmodular.org/forums/app.php/feed/topic/26642011-01-14T23:27:17+01:002011-01-14T23:27:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17749#p17749Statistics: Posted by héliouk 6 — 14 Jan 2011, 23:27
]]>2011-01-14T09:12:56+01:002011-01-14T09:12:56+01:00https://brainmodular.org/forums/viewtopic.php?t=2664&p=17742#p17742absolutely not tempered ! by default pitch values are rounded but if you connect a fader with a x.xx precision to the pitch inlet, the pitch will be have the same precision. You can have a 12.45 pitch if you want!
