ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-12-31T18:41:48+02:00https://brainmodular.org/forums/app.php/feed/topic/26462010-12-31T18:41:48+02:002010-12-31T18:41:48+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17623#p17623"gates" as a chain, seems not that complex.
gonna make some test with this or midiport and report if find a nice way..
]]>2010-12-31T03:52:56+02:002010-12-31T03:52:56+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17617#p17617 Oh crap, I forgot. I already have a way. It involves VST plugins in Usine that directly access midi ports, and virtual midi ports receiving the midi in Live..doh! (ps Senso, Usine native modules that could directly access midi in and midi out ports would make lots of sense)
So yea, there is a workaround for this problem, I've just been out of the loop and have forgotten everything as usual. Pizmidi MidiOut and any virtual midi (loopback) should work.
Statistics: Posted by gurulogic — 31 Dec 2010, 02:52
]]>2010-12-31T01:12:06+02:002010-12-31T01:12:06+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17614#p17614Statistics: Posted by 23fx23 — 31 Dec 2010, 00:12
2010-12-31T00:52:25+02:002010-12-31T00:52:25+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17613#p17613 About Midi integration, IMHO Live made great progress when v7 came out but v8 has not bring any Midi improvements.
]]>2010-12-31T00:46:43+02:002010-12-31T00:46:43+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17612#p17612, despite what i thought at start. (i felt it would be more limited but seems equivalent and more worflow friendly).
live can succesfully drive some midi to one of the 16 individual ins of usine, and we get the access to those 16 choice from routing scroller, so maybe the reverse (usine x midi outs) could be reachable by live routing as well? i could never test that from another vst in live, maybe live is corrupt regarding this, any one succesfully tested?
yeah real shame live can't channel filter, that would work directly as is...
]]>2010-12-31T00:21:27+02:002010-12-31T00:21:27+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17611#p17611Statistics: Posted by soundmind — 30 Dec 2010, 23:21
]]>2010-12-31T00:14:49+02:002010-12-31T00:14:49+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17610#p17610 It probably won't make a darned fifference but you could email the Abes and ask wtf is up with the midi limitations in Live. I know I have (not in the same words) and nothing has ever changed, but the more voices grumbling, the better.
Statistics: Posted by gurulogic — 30 Dec 2010, 23:14
]]>2010-12-30T23:57:35+02:002010-12-30T23:57:35+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17609#p17609Statistics: Posted by soundmind — 30 Dec 2010, 22:57
]]>2010-12-30T23:30:36+02:002010-12-30T23:30:36+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17608#p17608i was thinking it would behave like usal vsti, a single instance having accessible multiple in/outs, that could be handy too. still, lot of thingz to test with this system..mmm
]]>2010-12-30T22:57:29+02:002010-12-30T22:57:29+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17607#p17607because im a bit lost in what i assumed. i only tested mono stuff for now.
let's say i wanna generate 4 differents sources from usine VSTi and get those 4sounds as independant tracks in live. do you have to create 4 differents usines instances? i could have 4 outs from a single vsti instance normally no?
because here i test with battery that is multi-out, and if creating a new track in live picking out of battery track, i can scroll and pick one of the 32 outs of the single battery vst instance. If i try to pick usine track, i don't have access to independant tracks, i just have pre/post with no busses listing... mmmm what do i miss....
]]>2010-12-30T21:59:54+02:002010-12-30T21:59:54+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17605#p17605Statistics: Posted by soundmind — 30 Dec 2010, 20:59
]]>2010-12-30T21:59:40+02:002010-12-30T21:59:40+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17604#p17604...
Statistics: Posted by gurulogic — 30 Dec 2010, 20:59
]]>2010-12-30T21:34:49+02:002010-12-30T21:34:49+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17603#p17603Unlike Usine, EasineVst will allow several independent instances loaded at the same time.
]]>2010-12-30T21:14:54+02:002010-12-30T21:14:54+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17602#p17602Statistics: Posted by soundmind — 30 Dec 2010, 20:14
]]>2010-12-30T21:13:39+02:002010-12-30T21:13:39+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17601#p17601 i was thinking that even one single instance could have multi out, being audio and midi. i when you drop a multiout vsti in live , you can pick from the scroller the independant audio out, from the single vsti instance, could that work the same with midi? can vsts have 'real' differents midi outputs?
]]>2010-12-30T21:01:48+02:002010-12-30T21:01:48+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17599#p17599When you have Usine VST inserted on a track in Live, you have all of Usine inserted on that track. That means that all audio and midi goes in and out through that one track in Live. Now as soon as you create another track in Live and add another "copy" of Usine, you are actually only adding another input and output for Usine into live. The VST audio interface is self explanatory . Each Usine VST inserted is similar to a physical audio port and can be used and manipulated just like an audio port, except instead of physical audio ports on a soundcard, you get VST audio ports. It is not the same with the midi in Usine VST. In the standalone version you get to choose which midi port each tracks midi gets received from or sent to, but in the VST version you do not. All midi inputs get from all inputs and all midi outputs get sent to all outputs. In some hosts this can be compensated with midi channnel filtering but in Live it cannot. I think the midi routing in Usine VST needs an overhaul as in my opinion midi and audio routing should behave exactly the same, plus as it stands, Usine VST, Live and multi-channel midi are seemingly impossible. (except maybe by elaborate message transformations or perhaps an OSC to VST midi plugin?)
Statistics: Posted by gurulogic — 30 Dec 2010, 20:01
]]>2010-12-30T20:44:16+02:002010-12-30T20:44:16+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17598#p17598 live indeed doesn't allow the midi channel filter from a vsti other track, wich is very absurd and would solve the pb easily. but it's supposed to catch several 'outputs' (not midi ch) from a vsti. and maybe we could see those individual outputs from usine, that's what guru logic suggest? dk then if live or usine related. i could never test another multi midi out vsti.. @soundmind, you say: even though both midi tracks in live are receiving from different usine inputs you could pick two differents usine outputs from live? I can only catch one here.. or you meant differents 'channels' out of usine?
]]>2010-12-30T20:35:59+02:002010-12-30T20:35:59+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17597#p17597 What I mean is say you have to midi channels in Live, each with an instance of Usine VSTI, then you create two midi channels in Live and have each one get midi from a Usine track, and then you playback channel 1 midi on track 1 in Usine, you will see the same midi signal midi appear in both midi tracks in Live. Does this make sense?
Statistics: Posted by gurulogic — 30 Dec 2010, 19:35
]]>2010-12-30T20:21:35+02:002010-12-30T20:21:35+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17596#p17596Statistics: Posted by nay-seven — 30 Dec 2010, 19:21
]]>2010-12-30T20:16:29+02:002010-12-30T20:16:29+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17595#p17595I reported this problem a long time ago but it never got dealt with for some reason...
Statistics: Posted by gurulogic — 30 Dec 2010, 19:16
]]>2010-12-30T20:07:17+02:002010-12-30T20:07:17+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17594#p17594I've test several midi monitor vst plugins and Live seems to transform any midi channel you send to channel 1 !!
and i've test with other vst sending midi( like midi looper ) not only Usine...something curious here..
Statistics: Posted by nay-seven — 30 Dec 2010, 19:07
]]>2010-12-30T19:58:30+02:002010-12-30T19:58:30+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17593#p17593Statistics: Posted by Floego — 30 Dec 2010, 18:58
]]>2010-12-30T19:06:08+02:002010-12-30T19:06:08+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17591#p17591-Testing in reaper , Usine behaves as expected relating midi channel routing. good!. -In cakewalk music creator it could not even do midi out through vst! but this is a limitation of music creator I think.
]]>2010-12-30T18:25:58+02:002010-12-30T18:25:58+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17590#p17590anyway , i suppose you can use a vst to do the job here a link : http://www.niallmoody.com/ndcplugs/ndcmidi.htm there's a vst named MIDI Channel Filter if you create a new midi track in Live and filter channel 1 with this plugin, route this track to vst1 and same for vst 2..must work..?
Statistics: Posted by nay-seven — 30 Dec 2010, 17:25
]]>2010-12-30T18:08:12+02:002010-12-30T18:08:12+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17589#p17589live can repick midi from usine track, but on the drop menu we only see one usinevst output, and can't choose the channel, so booth are merged.
by waiting i would filter via pitching way up one of the other and using the scale of ableton, but find it strange, i suppose we could access booth independantly maybe..., any ideas olivier?
]]>BrainModularBrainModular Users Forum2010-12-31T18:41:48+02:00https://brainmodular.org/forums/app.php/feed/topic/26462010-12-31T18:41:48+02:002010-12-31T18:41:48+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17623#p17623"gates" as a chain, seems not that complex.
]]>2010-12-31T00:52:25+02:002010-12-31T00:52:25+02:00https://brainmodular.org/forums/viewtopic.php?t=2646&p=17613#p17613 About Midi integration, IMHO Live made great progress when v7 came out but v8 has not bring any Midi improvements.
