ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-12-02T00:07:34+01:00 https://brainmodular.org/forums/app.php/feed/topic/2582 2010-12-02T00:07:34+01:00 2010-12-02T00:07:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17259#p17259 <![CDATA[beatformer: granular drum sampler/sequencer]]>
really good patches !
thanx
Statistics: Posted by waolelaid — 02 Dec 2010, 00:07
2010-12-01T05:18:58+01:00 2010-12-01T05:18:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17240#p17240 <![CDATA[beatformer: granular drum sampler/sequencer]]>
just tested deeply: you're a killer man!
It's too easy in usine.
Statistics: Posted by soundmind — 01 Dec 2010, 05:18
2010-11-30T14:50:18+01:00 2010-11-30T14:50:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17238#p17238 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by senso — 30 Nov 2010, 14:50
2010-11-23T21:26:14+01:00 2010-11-23T21:26:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17137#p17137 <![CDATA[beatformer: granular drum sampler/sequencer]]> maybe to save cpu some subpatchs could be activated/swich off on need?
Statistics: Posted by 23fx23 — 23 Nov 2010, 21:26
2010-11-23T13:33:16+01:00 2010-11-23T13:33:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17128#p17128 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by soundmind — 23 Nov 2010, 13:33
2010-11-23T11:03:55+01:00 2010-11-23T11:03:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17126#p17126 <![CDATA[beatformer: granular drum sampler/sequencer]]> about cpu, i know it's a headache, but you can maybe try a no bus version, only wires...?
you could win some %
Statistics: Posted by nay-seven — 23 Nov 2010, 11:03
2010-11-23T10:48:24+01:00 2010-11-23T10:48:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17124#p17124 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by soundmind — 23 Nov 2010, 10:48
2010-11-23T03:21:50+01:00 2010-11-23T03:21:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17118#p17118 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by soundmind — 23 Nov 2010, 03:21
2010-11-22T22:28:56+01:00 2010-11-22T22:28:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17114#p17114 <![CDATA[beatformer: granular drum sampler/sequencer]]>
Statistics: Posted by caco — 22 Nov 2010, 22:28
2010-11-22T12:19:18+01:00 2010-11-22T12:19:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17102#p17102 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by soundmind — 22 Nov 2010, 12:19
2010-11-22T12:10:16+01:00 2010-11-22T12:10:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17101#p17101 <![CDATA[beatformer: granular drum sampler/sequencer]]> maybe a pan for each sample could be interesting..?
Statistics: Posted by nay-seven — 22 Nov 2010, 12:10
2010-11-22T11:14:24+01:00 2010-11-22T11:14:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17100#p17100 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by soundmind — 22 Nov 2010, 11:14
2010-11-22T09:05:33+01:00 2010-11-22T09:05:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17098#p17098 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by 23fx23 — 22 Nov 2010, 09:05
2010-11-22T07:37:51+01:00 2010-11-22T07:37:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17097#p17097 <![CDATA[beatformer: granular drum sampler/sequencer]]> Statistics: Posted by soundmind — 22 Nov 2010, 07:37
2010-11-21T12:04:28+01:00 2010-11-21T12:04:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=2582&p=17084#p17084 <![CDATA[beatformer: granular drum sampler/sequencer]]>
"Inspired by transformer, beatformer is an in depth granular drum sampler/sequencer. Although it was deisigned with drums in mind, any one shot samples can be used to create original rhythmic pieces from scratch."
http://www.sensomusic.com/wiki/doku.php ... beatformer
Check preset manager or conductor for a couple quick and dirty examples.
UPDATE3:
1. Lower CPU load
2. panning fader and mono switch for each sample
3. pre gain and post vol for each sample
4. sample start and end pos can now be adjusted from the waveform display as well as from the faders.
5. new envelope activation switch and option to trigger envelope with global sequencer or with repeat triggers.
6. brand new master section with master compressor and master vol/pan controlls
7. enhanced GUI design.
Statistics: Posted by soundmind — 21 Nov 2010, 12:04
thanx
UPDATE3:
1. Lower CPU load
