ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-02-18T11:55:02+01:00 https://brainmodular.org/forums/app.php/feed/topic/255 2007-02-18T11:55:02+01:00 2007-02-18T11:55:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=255&p=1234#p1234 <![CDATA[questions/suggestions]]> so...
Statistics: Posted by nay-seven — 18 Feb 2007, 11:55
2007-02-18T11:34:44+01:00 2007-02-18T11:34:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=255&p=1230#p1230 <![CDATA[questions/suggestions]]>
about stopping the audio engine
It's not only 'stopping the audio engine', but close the driver, cleanup the memory, etc...
If you make sound design I suggest you to buy a 'multi client' sound card that allows the playing of multiple applications simultaneously.
Don't you think it's finally simpler?
Statistics: Posted by senso — 18 Feb 2007, 11:34
2007-02-18T10:32:19+01:00 2007-02-18T10:32:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=255&p=1228#p1228 <![CDATA[questions/suggestions]]>
about stopping the audio engine , an other example : i record some tracks , and want to check the result in winamp , for that i've to go in the setup panel and stop the asio4all driver , if not winamp give me an error..same if i made a pause in my creation and go on website with music streaming ( myspace for example..)
if you insist..
don't want to bother you with that...;-)
but time to time i made a little change to a song , then phone or a visit , forget my changes and close usine without saving...i know i've a little HD for brain...
Statistics: Posted by nay-seven — 18 Feb 2007, 10:32
2007-02-13T16:26:19+01:00 2007-02-13T16:26:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=255&p=1188#p1188 <![CDATA[questions/suggestions]]>
a way to delete last track added..?
A lot of other stuffs like that: insert, delete, move...
maybe a way to confige usine ( in setup ) to stop audio engine when minimize..?
I'm not sure I understand the reason?
could be usefull to edit a sample in an other software
Yes I'll see what I can do.
a way to name a patch in the grid window without to save it as a patch before..?
Dangerous? Actually you can rename the track.
yet asked but when i close usine , could be cool to have a
" the current workspace has been modified
do you want to save changes , yes , no ,cancel... "
If you insist!!!
Statistics: Posted by senso — 13 Feb 2007, 16:26
2007-02-13T10:50:50+01:00 2007-02-13T10:50:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=255&p=1185#p1185 <![CDATA[questions/suggestions]]>
Statistics: Posted by nay-seven — 13 Feb 2007, 10:50
if you insist..
If you insist!!!
