ArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-11-08T10:14:39+02:00https://brainmodular.org/forums/app.php/feed/topic/25412010-11-08T10:14:39+02:002010-11-08T10:14:39+02:00https://brainmodular.org/forums/viewtopic.php?t=2541&p=16824#p16824 nay-seven, I think you understand correctly. The toggle idea is clever but unfortunately this only allows it to repeat on the second start only. I failed to mention that in some cases the local sync would be 2 times or 4 times, etc duration of the master.
Clearscreen, I actually tried something similar to yours but didn't think of using a counter.
I will try to work out a solution from these great ideas.
Statistics: Posted by soundmind — 08 Nov 2010, 09:14
[EDIT] Hmmmm, this should work shouldn't it? It's not restarting the local sync cycle though. The '0 to 1' is definitely sending a blip and I can restart the local sync cycle by hitting restart on the module but it's not doing - confusing!?!
[EXTRA EDIT!!] Just fixed it by putting a button between the '0 to 1' and the restart - should that be necessary? Also tried with an LED module and it wouldn't work. Very strange? Is the '0 to 1' too fast at the moment?
PS - this is really kinda handy for keeping piano rolls in sync with other ones - COOL!
Statistics: Posted by Clearscreen — 08 Nov 2010, 00:18
Statistics: Posted by nay-seven — 07 Nov 2010, 19:54
]]>2010-11-07T20:11:12+02:002010-11-07T20:11:12+02:00https://brainmodular.org/forums/viewtopic.php?t=2541&p=16806#p16806Statistics: Posted by soundmind — 07 Nov 2010, 19:11
Statistics: Posted by nay-seven — 07 Nov 2010, 16:53
]]>2010-11-07T12:14:51+02:002010-11-07T12:14:51+02:00https://brainmodular.org/forums/viewtopic.php?t=2541&p=16801#p16801 When does the activation module send a 1 value? It does not seem to work with play or audio on.
Statistics: Posted by soundmind — 07 Nov 2010, 11:14
]]>2010-11-07T11:43:52+02:002010-11-07T11:43:52+02:00https://brainmodular.org/forums/viewtopic.php?t=2541&p=16799#p16799can a toggle module do the job..? this way he start each second time..?
and a on activation module on the on inlet of local synchro..
Statistics: Posted by nay-seven — 07 Nov 2010, 10:43
]]>2010-11-07T11:05:32+02:002010-11-07T11:05:32+02:00https://brainmodular.org/forums/viewtopic.php?t=2541&p=16798#p16798 To anyone who has a simple solution to this, I am trying to sync a local syncro with a 8 cycle len to the master with a 4 cyc len. Or, another way to describe what I am trying to do is make a step modules duration double the duration of the master cycle so it repeats exactly in sync to every second cycle. Ive tried linking the on outlet of the master syncro to a 0 to 1 module then into the restart of the local syncro to restart it on time but I also need it to restart when audio is turned on from the dashboard. Maybe there is a way to double the length of the steps module with some maths and do away with the local syncro entirely? The steps will be used to trigger a swap of the values in another steps which is sequencing a synth so exact timing precision is necessary.
Statistics: Posted by soundmind — 07 Nov 2010, 10:05
]]>BrainModularBrainModular Users Forum2010-11-08T10:14:39+02:00https://brainmodular.org/forums/app.php/feed/topic/25412010-11-08T10:14:39+02:002010-11-08T10:14:39+02:00https://brainmodular.org/forums/viewtopic.php?t=2541&p=16824#p16824 nay-seven, I think you understand correctly. The toggle idea is clever but unfortunately this only allows it to repeat on the second start only. I failed to mention that in some cases the local sync would be 2 times or 4 times, etc duration of the master.
]]>2010-11-07T17:53:50+02:002010-11-07T17:53:50+02:00https://brainmodular.org/forums/viewtopic.php?t=2541&p=16803#p16803
